Discuss
GE Washer overfilling
 in
Washer Repair
My sister has a relatively new GE washing machine that overfills the tub on all load settings. What is the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer overfilling
  #1 (permalink)
Old 01-02-2013, 11:39 AM
Junior Member
vman1 is on a distinguished road
Default GE Washer overfilling
Model Number: WLSR2010K4WW   Brand: GE   Age: 1 - 5 years
My sister has a relatively new GE washing machine that overfills the tub on all load settings. What is the best first step to diagnose the problem?
Thank you, Victor
Ads By Google
Related Models
General Electric WLSR2010K4WW WASHER
General Electric WLSR2200J3WW WASHER
General Electric WLSR2200J5WW WASHER
General Electric WLSR2200J6WW WASHER
General Electric WLSR2200J7WW WASHER
General Electric WLSR2200J8WW WASHER
General Electric WLSR2200J9WW WASHER
General Electric WLSR3000G0WW Washer
General Electric WLSR3000G1WW WASHER
General Electric WLSR3000G2WW WASHER
General Electric WLSR3000G3WW WASHER
General Electric WLSR3000G4WW WASHER
General Electric WLSR3000G5WW WASHER
General Electric WLSR3000G6WW WASHER
Frigidaire WLW0 Frg(v1) / 27 " Washer
Frigidaire WLW1 Frg(v1) / 27 " Washer
General Electric WLW1500BAL Washer
General Electric WLW1500BBL Washer
General Electric WLW1500BCL Washer
General Electric WLW1500BNL Washer
General Electric WLW1500RBL Washer
General Electric WLW2330BAL Washer
General Electric WLW2500BAL Washer
General Electric WLW2500BBL Washer
General Electric WLW2500BCL Washer
General Electric WLW2500BNL Washer
General Electric WLW2500RBL Washer
Frigidaire WLW3 Frg(v1) / 27 " Washer
General Electric WLW3000BAL Washer
General Electric WLW3000BBL Washer
General Electric WLW3000BCL Washer
General Electric WLW3000BNL Washer
General Electric WLW3000RBL Washer
General Electric WLW3000SALWH Washer
General Electric WLW3200SALWH Washer
General Electric WLW3200SBLWH Washer
General Electric WLW3300BBL Washer
General Electric WLW3300BCL Washer
General Electric WLW3300BNL Washer
General Electric WLW3300RBL Washer
General Electric WLW3310BBL Washer
General Electric WLW3310BCL Washer
General Electric WLW3310BNL Washer
General Electric WLW3310RBL Washer
General Electric WLW3400SALAD Washer
General Electric WLW3400SALWH Washer
General Electric WLW3400SBLAD Washer
General Electric WLW3400SBLWH Washer
General Electric WLW3440SALAD Washer
General Electric WLW3440SALWH Washer
General Electric WLW3440SBLAD Washer
General Electric WLW3440SBLWH Washer
General Electric WLW3500BAL Washer
General Electric WLW3500BBL Washer
General Electric WLW3500BCL Washer
General Electric WLW3500BNL Washer
General Electric WLW3500RBL Washer
General Electric WLW3505BAL Washer
General Electric WLW3505BBL Washer
General Electric WLW3600BBL Washer
General Electric WLW3600BCL Washer
General Electric WLW3600BNL Washer
General Electric WLW3600SALAD Washer
General Electric WLW3600SALWH Washer
General Electric WLW3600SBLAD Washer
General Electric WLW3600SBLWH Washer
General Electric WLW3610SALWW Washer
General Electric WLW3610SBLWW Washer
General Electric WLW3700BAL Washer
General Electric WLW3700BBL Washer
General Electric WLW3700BCL Washer
General Electric WLW3700BNL Washer
General Electric WLW3700BPL Washer
General Electric WLW3700RBL
General Electric WLW3700RBLWW Washer
General Electric WLW3750BAL Washer
General Electric WLW3750BBL Washer
General Electric WLW3750BNL Washer
General Electric WLW3750RBL Washer
General Electric WLW3760RBLWW Washer
General Electric WLW3800SALAD Washer
General Electric WLW3800SALWH Washer
General Electric WLW3800SBLAD Washer
General Electric WLW3800SBLWH Washer
General Electric WLW3810SALWW Washer
General Electric WLW3810SBLWW Washer
General Electric WLW4700BAL Washer
General Electric WLW4700BBL Washer
General Electric WLW4700BCL Washer
General Electric WLW4700BNL Washer
General Electric WLW5700BAL Washer
General Electric WLW5700BBL Washer
General Electric WLW5700BCL Washer
General Electric WLW5700BNL Washer
General Electric WLW5700RBL Washer
General Electric WLW5900MAL Washer
General Electric WLW5900MNL Washer
Frigidaire WLXG42RED0 Wwh(v1) / Laundry Center
White Westinghouse WLXG42RED1 Laundry Center - W.westinghouse
Frigidaire WLXG42RED3
Frigidaire WLXG42REW0 Wwh(v2) / Laundry Center
White Westinghouse WLXG42REW1 Laundry Center - W.westinghouse
White Westinghouse WLXG42REW2 Laundry Center - West/famsa
White Westinghouse WLXG42REW3 White Westinghouse/laundry Center
White Westinghouse WLXG42REW4 White Westinghouse/laundry Center
White Westinghouse WLXG42REW5 White Westinghouse/laundry Center
General Electric WLXR1020T2WB Washer
General Electric WLXR1020T3WB Washer
General Electric WLXR1020T4WB Washer
General Electric WLXR1020T5WB Washer
General Electric WLXR1020T8WB Washer
General Electric WLXR1020TAWB Washer
 WM0001HTMA Washer
 WM0532HW Washer
 WM0642HW Washer
 WM0742HGA Washer
 WM0742HWA Washer
 WM1333HW Washer
 WM1812CW Washer
 WM1814CW Washer
  #2 (permalink)
Old 01-02-2013, 03:25 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Remove the front panel by inserting a putty knife into the groove at the top in line with the lid opening on each side to release the clips. Tilt the panel outward and lift off the cabinet. Check the air dome and hose on the left side of the tub for gunk that may be clogging it up. Check that the hose fitting is tight. If all is ok, open the control panel and check the hose fitting at the pressure switch on the left side. If ok, check continuity on the pressure switch. You will have to disconnect the hose at the air dome and blow into it to activate the switch. You should normally have continuity across the terminals where the yellow/black and brown wires attach and when you blow into the hose to activate the switch, you should have an open circuit across those terminals and continuity across yellow/black and violet wires.
Eric
  #3 (permalink)
Old 01-02-2013, 05:28 PM
Junior Member
Default Thank you
Quote:
Eric
Took off unit front...Immediately saw gunk at the hose end...Removed the stuff and reassembled...My sister ran a small load and all seemed fine...It filled and washed normally but she tells me it does not spin out on the small cycle only...Large & super spins fine it is just the small load that has the problem? Not sure but I will start searching the forum on this topic! Thank you for the help!
  #4 (permalink)
Old 01-02-2013, 05:48 PM
Expert
APP Volunteer
Default
This is probably still related to the water level switch. There is probably some gunk inside the air dome which can be difficult to clean out. A turkey baster with hot soapy water can be used to flush it out after disconnecting the hose. Be careful doing this as you don't want to break the hose bib off of the air dome.
Eric
  #5 (permalink)
Old 01-03-2013, 06:43 AM
Junior Member
Default GE washer
Eric
Thanks Eric...I thought I had the problem fixed...Could you explain how the pressure switch would affect the spin out on the small cycle? I have no problems replacing that switch but is it possible that the spin problem is related to a control timer?
  #6 (permalink)
Old 01-03-2013, 07:26 AM
Expert
APP Volunteer
Default
The load size control directly controls the pressure switch. The timer would have no effect unless a different wash cycle was run when using the small load size setting. If your running the same wash cycle with different load size settings and it spins fine on large and super but not on small, then it must have something to do with the pressure switch.
Eric
  #7 (permalink)
Old 01-03-2013, 10:59 AM
Junior Member
Default
Eric
Eric...thank you. I understand...I will look into that switch and the hose connection on the switch and check it for continuity as well...Take care, Victor
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer overfilling runningspike Washer Repair 2 02-21-2011 05:21 AM
help with GE washer overfilling doomee Washer Repair 1 12-15-2009 03:29 PM
washer overfilling scotte Washer Repair 2 10-08-2009 06:31 AM
Washer Overfilling jtowntbo5@yahoo.com Washer Repair 4 01-08-2009 03:48 PM
Washer overfilling xmasbaby63 Washer Repair 2 08-16-2008 08:33 PM
