Discuss
GE washer won't spin - Mark
 in
Washer Repair
Washer fills and agitates. Washer won't spin or pump-out. Timer continues to advance without stopping (goes thru one complete cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer won't spin - Mark
  #1 (permalink)
Old 01-02-2013, 10:45 AM
Junior Member
masavrin@netzero.net is on a distinguished road
Default GE washer won't spin - Mark
Model Number: wcsr2090d5ww   Brand: GE   Age: 5 - 10 years
Washer fills and agitates. Washer won't spin or pump-out. Timer continues to advance without stopping (goes thru one complete cycle to the next complete cycle, etc.)
Ads By Google
Related Models
General Electric WCSR2090D5WW Washer
General Electric WCSR2090D6WW Washer
General Electric WCSR2090D7WW Washer
General Electric WCSR2090D8WW Washer
General Electric WCSR2090DACC Washer
General Electric WCSR2090DAWW Washer
General Electric WCSR2090DBCC Washer
General Electric WCSR2090DBWW Washer
General Electric WCSR2090DCCC Washer
General Electric WCSR2090DCWW Washer
General Electric WCSR2090DDCC Washer
General Electric WCSR2090DDWW Washer
General Electric WCSR2090DGCC Washer
General Electric WCSR2090DGWW Washer
General Electric WCSR2090G0CC Washer
General Electric WCSR2090G0WW Washer
General Electric WCSR2090G1CC Washer
General Electric WCSR2090G1WW Washer
General Electric WCSR2090G2CC Washer
General Electric WCSR2090G2WW Washer
General Electric WCSR4110T6AA Washer
General Electric WCSR4110T6WW Washer
General Electric WCSR4110T8AA Washer
General Electric WCSR4110T8WW Washer
General Electric WCSR4110TAAA Washer
General Electric WCSR4110TAWW Washer
General Electric WCSR4110TBAA Washer
General Electric WCSR4110TBWW Washer
General Electric WCSR4110TCAA Washer
General Electric WCSR4110TCWW Washer
General Electric WCSR4170D0CC Washer
General Electric WCSR4170D0WW Washer
General Electric WCSR4170D5CC Washer
General Electric WCSR4170D5WW Washer
General Electric WCSR4170D6CC Washer
General Electric WCSR4170D6WW Washer
General Electric WCSR4170DACC Washer
General Electric WCSR4170DAWW Washer
General Electric WCSR4170DCCC Washer
General Electric WCSR4170DCWW Washer
General Electric WCSR4170G0CC Washer
General Electric WCSR4170G0WW Washer
Thermador WCTD5500
Amana WCU-514 Range - S/c S/i Ddraft Gas
Amana WCU-514C Range - S/c S/i Ddraft Gas
Amana WCU-514D Range - S/c S/i Ddraft Gas
Amana WCU-514E Range - S/c S/i Ddraft Gas
Amana WCU-514F Range - S/c S/i Ddraft Gas
Amana WCU-516 Range - S/c S/i Ddraft Gas
Amana WCU-516A Range - S/c S/i Ddraft Gas
Amana WCU-516C Range - S/c S/i Ddraft Gas
Amana WCU-516D Range - S/c S/i Ddraft Gas
Amana WCU-516F Range - S/c S/i Ddraft Gas
General Electric WCVH6260F0GG Washer
General Electric WCVH6260F0WW Washer
General Electric WCVH6260H0WW Washer
General Electric WCVH6600H0BB Washer
General Electric WCVH6600H0GG Washer
General Electric WCVH6600H0WW Washer
General Electric WCXR1070A0AA Washer
General Electric WCXR1070A0WW Washer
General Electric WCXR1070A1AA Washer
General Electric WCXR1070A1WW Washer
General Electric WCXR1070A2AA Washer
General Electric WCXR1070A2WW Washer
General Electric WCXR1070T2AA Washer
General Electric WCXR1070T2WW Washer
General Electric WCXR1070T3AA Washer
General Electric WCXR1070T3WW Washer
General Electric WCXR1070T4AA Washer
General Electric WCXR1070T4WW Washer
General Electric WCXR1070T5AA Washer
General Electric WCXR1070T5WW Washer
General Electric WCXR1070T8AA Washer
General Electric WCXR1070T8WW Washer
General Electric WCXR1070TAAA Washer
General Electric WCXR1070TAWW Washer
General Electric WCXR1070TBAA Washer
General Electric WCXR1070TBWW Washer
Magic Chef WCZ1050 Washer - Top Loading
Magic Chef WCZ1050AM Washer - Top Loading
Magic Chef WCZ1050W Washer - Top Loading
Thermador WD24
Thermador WD24N
Thermador WD24NS
Thermador WD24NW
Thermador WD24QB
Thermador WD24QPRS
Thermador WD24QS
Thermador WD24QW
Thermador WD24S
Thermador WD24W
Thermador WD24WC
Thermador WD27QB
Thermador WD27QPRS
Thermador WD27QS
Thermador WD27QW
Frigidaire WD300J Wwh(v1) / Disposer
Frigidaire WD301J Wwh(v2) / Disposer
Thermador WD30XB
Thermador WD30XP
Thermador WD30XS
Thermador WD30XW
Frigidaire WD350M Wwh(v3) / Disposer
Frigidaire WD500J Wwh(v3) / Disposer
Frigidaire WD550J Wwh(v1) / Disposer
Frigidaire WD551J Wwh(v2) / Disposer
Frigidaire WD750J Wwh(v3) / Disposer
Frigidaire WD850J Wwh(v1) / Disposer
White Westinghouse WDB11NRDB0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDB1 White Westinghouse/dishwasher
White Westinghouse WDB11NRDB2 White Westinghouse/dishwasher
White Westinghouse WDB11NRDQ0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS1 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS2 White Westinghouse/dishwasher
Frigidaire WDB212GBD0 Wwh(v2) / 24 " Built - in Dishwasher
Frigidaire WDB212GBW0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB212RBM0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB222RBR0 Wwh(v1) / 24 " Built - in Dishwasher
  #2 (permalink)
Old 01-02-2013, 11:24 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Sounds like a water pump problem. Can you hear the pump come on after agitation stops? If not, check for 120vac across the wire terminals on the pump. If good and the pump won't run, replace the pump. If the pump is running but won't pump out, drain manually and remove hoses to check for obstructions or damage inside the pump. If you don't get 120vac across the pump, replace the timer. To remove the front panel, insert a putty knife into the top groove in line with the lid opening on each side to release the clips, tilt panel out and lift from cabinet. Pump is on lower right side.
Eric
  #3 (permalink)
Old 01-03-2013, 10:49 AM
Junior Member
Default
You were right! I rechecked the symptoms and found that, due to large water load, I could not hear the spin cycle. I confirmed that the lid-switch was working. The pump was trying to work, but due to a wad of quilt-stuffing, the water couldn't enter the pump. I removed the stuffing and everything is OK. What I can't explain is why the timer wouldn't shut off; it kept circling to subsequent cycles. After I corrected the pump-problem, the timer was fine. Go figure. Thanks
  #4 (permalink)
Old 01-03-2013, 03:35 PM
Expert
APP Volunteer
Default
The timer kept going because with no drain, the water level pressure switch was always in the full position, which connects power to the timer motor.
Eric
  #5 (permalink)
Old 01-04-2013, 07:33 AM
Junior Member
Default
Good explanation! Makes sense. Thanks for the help. Over and out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer won't spin - Mark masavrin@netzero.net Washer Repair 0 01-02-2013 10:41 AM
mark markdunsmore Washer Repair 2 07-27-2012 06:35 AM
Mark raelbrand@bellsouth.net Washer Repair 3 12-26-2011 05:43 AM
mark chimblo Washer Repair 3 07-12-2011 03:52 PM
Mark O Mark O Dishwasher Repair 0 10-05-2009 12:25 PM
