jcpacocha
#1 Posted : Sunday, February 3, 2008 10:00:57 AM(UTC)
jcpacocha
Wash cycle stops randomly, usually at rinse and spin cycles. Advancing the control knob slightly and re-starting, it will run till it reaches the next rinse cycle. Is this a timer or control knob issue.
#2 Posted : Monday, February 4, 2008 10:15:05 AM(UTC)
Most likely the problem is restricted water flow due to a clog in the water inlet valve.
To supply you with the right part number for the water inlet valve I need the serial number of the washer.
