Discuss
20yr washer very loud on spin cycle
 in
Washer Repair
Our 20+yr old washer is making a loud roar, almost like a plane is landing or something! Balance has been
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 20yr washer very loud on spin cycle
  #1 (permalink)
Old 01-01-2013, 02:52 PM
Junior Member
standlbe is on a distinguished road
Default 20yr washer very loud on spin cycle
Brand: White-Westinghouse   Age: More than 10 years
Our 20+yr old washer is making a loud roar, almost like a plane is landing or something! Balance has been checked & seems to be alright. Since it's such an old machine is this worth repairing?
Thanks!
Bev
Ads By Google
  #2 (permalink)
Old 01-02-2013, 03:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Bev,
Such repair can be pretty expensive. So your decision should be based on condition of the washer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-03-2013, 05:57 AM
Member
ramblinche81 is on a distinguished road
Default Center shaft bearing or transmission failed
Quote:
Thanks!
Bev
Look under your machine, is there water (leaking center shaft bearing) or a reddish or brown oily material (transmission seal leak) ?
If it is just water, and based on noise, the likely problem is the main bearing for the driveshaft. Some models it is a 30minute fix, some it is a 3hour fix. Most independent shops, if you call them and ask what they would charge to replace the center bearing and drive shaft (it is usually a kit) they will tell you an estimate.
If there is brown or reddish oil, then your transmission is lost as well.
The good news is you have 20 years of value in the machine. THe bad news is new machines won't last 20 years.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Washer Very Loud On Spin Cycle lynkers Washer Repair 1 10-19-2012 05:31 PM
loud washer in spin cycle Dan111 Washer Repair 3 02-23-2012 04:55 AM
washer is very loud in spin cycle mlee Washer Repair 1 06-20-2011 08:43 AM
Washer Spin Cycle Very Loud dradspin Washer Repair 4 07-02-2010 11:03 AM
washer loud spin cycle rottweiler Washer Repair 4 01-10-2010 09:09 AM
