| » Noise when going from spin to stop |
Model Number: LSQ9010LW1 Brand: Whirlpool Age: 5 - 10 years
I have a 2003 Whirlpool washer. It make a noise after the spin cycle stop is ingauged. It washers & spins without a problem. It only makes the noise when it goes into the stop mode after the spin cycle is compete.
Quote:
Could be the brakes grabbing. You can try placing a very small amount of brake lubricant like Sil-Glyde onto the inside surface of the brake drum with a small screwdriver. Next time the washer goes into spin, the brake linings will pick up and spread the lube around and hopefully cure the problem. If this doesn't work, you'll need to pull the gearcase again and inspect the brake linings and mechanism.
Eric Last edited by fairbank56 : 01-04-2013 at 11:29 AM. |
| Display Modes | |
| Clicking noise - won't stop | keysrose | Oven Repair (including Ranges and Cooktops) | 1 | 08-31-2011 07:24 AM |
| Loud noise and rough stop during spin cycle | wattersa81 | Washer Repair | 6 | 04-30-2011 04:07 PM |
| Grinding Noise on Spin Stop | PATRIOT | Washer Repair | 2 | 04-23-2011 08:01 PM |
| Non-Stop noise come from top panel suddenly | B1_lee | Oven Repair (including Ranges and Cooktops) | 0 | 12-16-2009 12:51 PM |
| Unit doesn't stop - tamping noise | Kenneth Cark | Trash Compactor Repair | 1 | 06-08-2009 11:08 AM |
