Discuss
Fridgidaire Gallery Does not drain water
 in
Washer Repair
Hello, I'm sorry I could not find the model number for my Fridgidaire Gallery top load washer. I found the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fridgidaire Gallery Does not drain water
  #1 (permalink)
Old 12-30-2012, 05:58 PM
Junior Member
Abe460 is on a distinguished road
Default Fridgidaire Gallery Does not drain water
Model Number: N/A   Brand: Frigidaire   Age: 5 - 10 years
Hello,
load washer. I found the tag, but it is faded to the only thing showing is the
UL listed symbol. I have the "Matching" drier and its model number is
GLER341AS2.
The washer goes through all the process until it should start draining water.
After aggitation the machine does nothing else. At that point the knob sounds like the normal low grinding as if a timer is working, but then it just clicks and stops. The knob doesn't go any farther.
I thought, through reading these forums, it could be the switch. I started
the washer aggitating and it stops when the lid is opened starts when it is closed. The lid lock never engages either. My thoughts would lead me to the controler which I'm sure is not cheap. However neither is a new machine so I'm here where the experts are.
Thank you for your time.
Abel
Ads By Google
Related Models
Norge N1100PAW Range - F/s Std Gas
Norge N1100PRA Range - F/s Std Gas
Norge N1100PRA-L Range - F/s Cont Clean Gas
Norge N1100PRW Range - F/s Std Gas
Norge N1100PRW-L Range - F/s Cont Clean Gas
Norge N1500PRA Range - F/s Std Ele
Norge N1500PRW Range - F/s Std Ele
Norge N31100PAA Range - F/s Std Gas
Norge N31100PAW Range - F/s Std Gas
Norge N3110KRA Range - F/s Std Gas
Norge N3110KRW Range - F/s Std Gas
Norge N3110PPA Range - F/s Std Gas
Norge N3110PPW Range - F/s Std Gas
Norge N3110PRA Range - F/s Std Gas
Norge N3110PRW Range - F/s Std Gas
Norge N31111XAA Range - F/s Std Gas
Norge N31111XAW Range - F/s Std Gas
Norge N31115WAV Range - F/s Std Gas
Norge N31115XAA Range - F/s Std Gas
Norge N31115XAW Range - F/s Std Gas
Norge N3120SPA Range - F/s Std Gas
Norge N3120SPN Range - F/s Std Gas
Norge N3120SPW Range - F/s Std Gas
Norge N3120SRA Range - F/s Std Gas
Norge N3120SRW Range - F/s Std Gas
Norge N3121XPA Range - F/s Std Gas
Norge N3121XPW Range - F/s Std Gas
Norge N3121XRA Range - F/s Std Gas
Norge N3121XRW Range - F/s Std Gas
Norge N3121XTA Range - F/s Std Gas
Norge N3121XTW Range - F/s Std Gas
Norge N3137XRA Range - F/s Std Gas
Norge N3137XRW Range - F/s Std Gas
Norge N3137XUA Range - F/s Std Gas
Norge N3137XUW Range - F/s Std Gas
Whirlpool N3157W0
Whirlpool N3157W1
Whirlpool N3157^0
Whirlpool N3157^1
Norge N3177VUV Range - F/s Std Gas
Norge N3177XRA Range - F/s Std Gas
Norge N3177XRW Range - F/s Std Gas
Norge N3177XUA Range - F/s Std Gas
Norge N3177XUW Range - F/s Std Gas
Whirlpool N3257W0
Whirlpool N3257W1
Whirlpool N3257^0
Whirlpool N3257^1
Whirlpool N3357W0
Whirlpool N3357^0
Norge N3422PRA Range - S/c F/s Gas
Norge N3422PRW Range - S/c F/s Gas
Norge N3438SRA Range - S/c F/s Gas
Norge N3438SRW Range - S/c F/s Gas
Norge N3438VRV Range - S/c F/s Gas
Whirlpool N3457W0
Whirlpool N3457^0
Norge N3472SRA Range - S/c F/s Gas
Norge N3472SRW Range - S/c F/s Gas
Norge N3478VRV Range - S/c F/s Gas
Norge N3478VVV Range - S/c F/s Gas
Norge N3478XRA Range - S/c F/s Gas
Norge N3478XRW Range - S/c F/s Gas
Norge N3478XVA Range - S/c F/s Gas
Norge N3478XVW Range - S/c F/s Gas
Norge N3510KRA Range - F/s Std Ele
Norge N3510KRW Range - F/s Std Ele
Norge N3510PPA Range - F/s Std Ele
Norge N3510PPW Range - F/s Std Ele
Norge N3510PRA Range - F/s Std Ele
Norge N3510PRW Range - F/s Std Ele
Norge N3520SPA Range - F/s Std Ele
Norge N3520SPN Range - F/s Std Ele
Norge N3520SPW Range - F/s Std Ele
Norge N3520SRA Range - F/s Std Ele
Norge N3520SRW Range - F/s Std Ele
Norge N3521XPA Range - F/s Std Ele
Norge N3521XPW Range - F/s Std Ele
Norge N3521XRA Range - F/s Std Ele
Norge N3521XRW Range - F/s Std Ele
Norge N3832XRA Range - S/c F/s Ele
Norge N3832XRW Range - S/c F/s Ele
Norge N3875XRA Range - S/c F/s Ele
Norge N3875XRW Range - S/c F/s Ele
Norge N3878VRV Range - S/c F/s Ele
Norge N3878VVD Range - S/c F/s Ele
Norge N3878VVV Range - S/c F/s Ele
Norge N3878XRA Range - S/c F/s Ele
Norge N3878XRW Range - S/c F/s Ele
Norge N3878XVA Range - S/c F/s Ele
Norge N3878XVW Range - S/c F/s Ele
Magic Chef N40C-3-X9 Mwave - Cntrtp / Stand Alone
Norge N4231WRA Range - F/s Cont Clean Gas
Norge N4231WRW Range - F/s Cont Clean Gas
Norge N4251WTA Range - F/s Std Gas
Norge N4251WTW Range - F/s Std Gas
Whirlpool N9157L0
Whirlpool N9157L1
Whirlpool N9157X0
Whirlpool N9157^0
Whirlpool N9157^1
Whirlpool N9257L1
Whirlpool N9257L2
Whirlpool N9257X0
Whirlpool N9257X1
Whirlpool N9257^0
Whirlpool N9257^1
Whirlpool N9257^2
Whirlpool N9357L0
Whirlpool N9357L2
Whirlpool N9357L3
Whirlpool N9357^0
Whirlpool N9357^2
Whirlpool N9357^3
Whirlpool N9457L3
Whirlpool N9457X0
Whirlpool N9457X2
Whirlpool N9457X3
Whirlpool N9457X4
Whirlpool N9457X5
  #2 (permalink)
Old 01-01-2013, 06:32 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I think you need to change out the lid lock assembly, but you will need to know the model number to get the right part.
__________________
  #3 (permalink)
Old 01-02-2013, 05:06 PM
Junior Member
Default
Quote:
Thank you for your answer and your time.
Just out of curiosity is there any other place the model number might be? I did remove the back of the controls, but no model number. If not can I remove the lock assembly and bring it to a parts warehouse to see if they can match it.
Also, (sorry, full of dumb questions) I would assume there would be a resistor in the assembly to supervise the latch if the control stops for it not being latched? If so is there a standard resistance or is it model specific?
  #4 (permalink)
Old 01-02-2013, 05:51 PM
Senior Expert
APP Volunteer
Default
The model number should be on the back on inside when you lift the lid. If this is a basic Frigidaire top loader then you should be able to remove the lid lock assembly and take it to the parts store for them to match up. the lid lock assembly is pretty common on Frigidaire top loader.
I don't know of any resistor or any other electrical control other than the timer which controls the operation of the lid lock.
__________________
  #5 (permalink)
Old 01-02-2013, 08:05 PM
Junior Member
Default
Sorry if I'm not looking in the right place or didn't describe it right in my first post...on the inside of the lid is a sticker/tag (upper right corner) that should have the model number, but it is blank white exept for a corner portion of the UL listed emblem.
If the timer controls the lid lock and the lid lock fails, would the timer know that the lid lock failed and stop function based on the lid lock not engaging?
  #6 (permalink)
Old 01-04-2013, 09:30 AM
Senior Expert
APP Volunteer
Default
Yes, if the lid lock does not engage the timer knows this and will not allow the machine to operate. This is a safety feature to prevent you from opening the lid and stick your arm in there while the machine is spinning. If you were to do that a broken arm is the typical result.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridgidaire dishwasher does not drain boblowe Dishwasher Repair 1 04-26-2012 02:44 AM
Fridgidaire Gallery Series Dishwasher Control Panel Malfunction?? Realtorman Dishwasher Repair 0 11-02-2011 04:01 AM
Fridgidaire Gallery Glass Cooktop-LARGE CHUNK CAME OUT Kiki Oven Repair (including Ranges and Cooktops) 6 09-02-2010 03:15 PM
what part do i need? Fridgidaire Gallery Dryer jenna.cox Dryer Repair 1 04-28-2009 05:14 PM
Fridgidaire Gallery series Side-by-Side built 08/95 Boomer1970 General Talk 3 10-08-2007 02:21 PM
