The cycle runs to completion, however the tub will not spin. The door lock indicator doesn't come on and the door will not lock. Please help.
The problem with diagnosing your machine is that there are so many possibilities that it is difficult to list them all. What immeditely comes to mind is the door lock assembly (particularly if you still have wax motors), the main control board, the wiring, the motor control board and a whole bunch of other things. Here is the service manual (with an update for your model in the back). There is a lot of trouble shooting info, so you are just going to have to take it one component at a time. http://www.servicematters.com/m...ibrary/docs/16010061.pdfGood luck
