Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Washer problem (http://forum.appliancepartspros.com/washer-repair/513217-washer-problem.html)
mabarker 12-28-2012 02:27 PM
Washer problem
The washer overfills then displays an E1 message, I have removed and cleaned the hose filters and the debris filter. The pump does not come on when it overfills, but works fine when switched to spin only. It pumps the water out, spins and stops at cycle end. I know there is a pressure hose somewhere that tells the water to shut off, I would like to know where it is, and if anyone has any helpful ideas. Thank you!
