Discuss
duet washer error codes
 in
Washer Repair
I I have had the same problems as others with this washer for about three years. Originally it was throwing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » duet washer error codes
  #1 (permalink)
Old 12-27-2012, 06:05 PM
Junior Member
Michele H is on a distinguished road
Default duet washer error codes
Model Number: ghw9150pwo   Brand: Whirlpool   Age: 5 - 10 years
I I have had the same problems as others with this washer for about three years. Originally it was throwing F11 and DL codes. Sometimes in mid cycle, sometimes the door would not lock, sometimes it would not UNlock. For awhile I would hit the top of the lid, and that seemed to work. Then I read about taking off the top lid, that worked for awhile, especially if I pushed on some of the connectors on the CCU. The connector in the MS2 slot was visibly loose, so I took off the top of the plastic casing on the CCU and would hold the conector down when there was a problem. Last week, the washer would turn on, the door lock would cycle the way it was supposed to, but the cycle would stop after a minute with a F11 code. I could not get it to go beyond a minute in the cycle without this occurring. I took the board out and resoldered the MS1 connector. There was visible black underneath that connector. Before I soldered, I noticed sparking under the white omron resistors during cycling when I was holding the loose MS1 connector in place. I even got shocked once or twice. I reinstalled everything and now the door lock just clicks and throws a DL code. The washer will not begin it's cycle. I followed the directions to run diagnostics (turn on washer, select spin/drain/select no spinI visibly inspected the connections to the door lock assembly. Also, the door lock was working before I soldered the board. I noticed on another post that someone suggested replacing the white omron resistors. They also mention three black resistors. I only see one black resistor. Could these resistors be the problem? WHat is the part number for the black resistors?
Ads By Google
Related Models
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
Whirlpool GI15NDXTQO Ice Cube Maker
Whirlpool GI15NDXTS0 Ice Cube Maker
Whirlpool GI15NDXTS1 Ice Cube Maker
Whirlpool GI15NFLTB0 Ice Cube Maker
Whirlpool GI15NFLTB1 Ice Cube Maker
Whirlpool GI15NFLTBO Ice Cube Maker
Whirlpool GI15NFLTS0 Ice Cube Maker
  #2 (permalink)
Old 12-28-2012, 01:43 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
These boards are not meant to be repaired, so my advice would be to replace it and to check out the connectors and the wiring, particularly wiring and connections to the door lock assembly.
If you purchase the board from this site and it does not fix the problem you can return it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
duet washer error codes jeep2412 Washer Repair 1 10-28-2011 06:34 PM
Whirlpool Duet SUD and F35 error codes richappy Washer Repair 4 09-07-2011 04:34 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 4 05-09-2011 09:01 PM
Whirlpool Duet F11 FDL error codes kirstenrdh Washer Repair 4 10-27-2010 01:34 PM
Whirlpool Duet Washer error codes F11 and DL tka1121 Washer Repair 1 12-30-2009 07:58 AM
