Discuss
How to remove agitator
 in
Washer Repair
HelpPlease!!!!!! Washer does everything but agitate. You can hear a grinding sounding but theagitator will not move. I have a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to remove agitator
  #1 (permalink)
Old 12-27-2012, 02:12 PM
Junior Member
just_chillin38 is on a distinguished road
Default How to remove agitator
Model Number: MWX433REW0   Brand: White-Westinghouse   Age: 5 - 10 years
HelpPlease!!!!!!
Washer does everything but agitate. You can hear a grinding sounding but theagitator will not move. I have a Westinghouse Model MWX433REW0 Washer.
Related Models
Frigidaire MWX433REW0 Frg(v2) / Washer
Frigidaire MWX433REW1 Frg(v2) / Washer
Frigidaire MWX433REW2 Frg(v2) / Washer
Frigidaire MWX433REW3 Frg(v2) / Washer
Frigidaire MWX445MBD0 Frg(v3) / 27 " Washer
Frigidaire MWX445MBD2 Frg(v1) / Washer
Frigidaire MWX445MBD3 Frg(v2) / Washer
Frigidaire MWX445MBD4 Frg(v1) / Washer
Frigidaire MWX445MBW0 Tap(v7) / 27 " Washer
Frigidaire MWX445MBW1 Frg/27" Washer
Frigidaire MWX445MBW2 Frg(v3) / Washer
Frigidaire MWX445MBW3 Frg(v4) / Washer
Frigidaire MWX445MBW4 Frg(v2) / Washer
Frigidaire MWX445MBWD0 Gib(v10) / 27 " Washer
Frigidaire MWX445MBWO Frg(v1) / 27 " Washer
Frigidaire MWX445MBWW0 Frg(v1) / 27 " Washer
Frigidaire MWX445RBD0 Frg(v4) / 27 " Washer
Frigidaire MWX445RBD2 Frg(v5) / Washer
Frigidaire MWX445RBD4 Frg(v3) / Washer
Frigidaire MWX445RBW0 Tap(v8) / 27 " Washer
Frigidaire MWX445RBW1 Frg/27" Washer
Frigidaire MWX445RBW2 Frg(v6) / Washer
Frigidaire MWX445RBW3 Frg(v5) / Washer
Frigidaire MWX445RBW4 Frg(v4) / Washer
Frigidaire MWX445RBWW0 Gib(v11) / 27 " Washer
Frigidaire MWX645RES0 Frg(v1) / Washer
Frigidaire MWX645RES1 Frg(v0) / Washer
Frigidaire MWX645RES2 Frg(v0) / Washer
Frigidaire MWX645RES3 Frg(v0) / Washer
Frigidaire MWX645RES4 Frg(v0) / Washer
Frigidaire MWX645RET0 Frg(v2) / Washer
Amana MX1550.000 COMMERCIAL MICROWAVES
Admiral MX400 REF - TOP MOUNT
Maytag MX410 REF - SXS
Maytag MX411 REF - SXS/I&W
Frigidaire MXLG62RBD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MXLG62RBW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MXW121RBW0-23 Tap(v8) / 27 " Washer
Admiral MYE3350AGW WASHER-TOP LOADING
Admiral MZ2727EEGB REF - SXS/I&W
Admiral MZ2727EEGW REF - SXS/I&W
Maytag MZD2663KEB REF - SXS/I&W
Maytag MZD2663KEQ REF - SXS/I&W
Maytag MZD2663KES REF - SXS/I&W
Maytag MZD2663KEW REF - SXS/I&W
Maytag MZD2665HEB REF - SXS/I&W
Maytag MZD2665HEQ REF - SXS/I&W
Maytag MZD2665HES REF - SXS/I&W
Maytag MZD2665HEW REF - SXS/I&W
Maytag MZD2666KEB REF - SXS/I&W
Maytag MZD2666KES REF - SXS/I&W
Maytag MZD2666KEW REF - SXS/I&W
Maytag MZD2667HEB REF - SXS/I&W
Maytag MZD2667HEQ REF - SXS/I&W
Maytag MZD2667HES REF - SXS/I&W
Maytag MZD2667HEW REF - SXS/I&W
Maytag MZD2669KEB REF - SXS/I&W
Maytag MZD2669KEQ REF - SXS/I&W
Maytag MZD2669KES REF - SXS/I&W
Maytag MZD2669KEW REF - SXS/I&W
Maytag MZD2752GRB REF - SXS/I&W
Maytag MZD2752GRQ REF - SXS/I&W
Maytag MZD2752GRS REF - SXS/I&W
Maytag MZD2752GRW REF - SXS/I&W
Maytag MZD2766GEB REF - SXS/I&W
Maytag MZD2766GEQ REF - SXS/I&W
Maytag MZD2766GES REF - SXS/I&W
Maytag MZD2766GEW REF - SXS/I&W
Maytag MZD2768GEB REF - SXS/I&W
Maytag MZD2768GEQ REF - SXS/I&W
Maytag MZD2768GEW REF - SXS/I&W
Whirlpool N N ELECTRIC RANGES AND OVENS
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
  #2 (permalink)
Old 12-27-2012, 02:34 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Unscrew the agitator cap, remove the screw and check through the center opening if the transmission shaft is moving back and forth in agitation.
If it does - pull out the agitator Part number: 5303937150
and check the splines inside and hub splines
Part number: 134418700
If not, then most likely it's a bad transmission
Here are the breakdown diagrams and Universal / Multiflex (frigidaire) Washer-5995285052 Motor / Tub parts for Frigidaire MWX433REW0 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-28-2012, 04:45 PM
Junior Member
Default Removing the agitator
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Post the results.
Simon.
I've removed the agitator, and the splines look fine. The shift will only turn in one direction. It will agitate if there are no clothes in the machine, once clothes are added then it will not agitate.
  #4 (permalink)
Old 12-28-2012, 05:32 PM
Expert
Default
Hi.
Check if you can hold the transmission shaft with you hands.
If you do - then it's bad tranny.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Remove agitator Larry225 Washer Repair 1 02-11-2010 07:28 PM
remove agitator mdallen9 Washer Repair 0 02-07-2010 08:12 PM
How to remove agitator kywoman43 Washer Repair 0 07-13-2009 10:14 AM
How Do I Remove Agitator? slowjoe_69 Washer Repair 1 11-06-2008 01:25 PM
remove agitator herman bart Washer Repair 1 09-11-2008 11:26 AM
