Discuss
Washer
 in
Washer Repair
My washer has power, but no command. Replaced the control board and didn't fix anything, what a waste of money.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer
  #1 (permalink)
Old 12-26-2012, 09:27 AM
Junior Member
dlinn56 is on a distinguished road
Default Washer
Model Number: GVW9959KQ1   Brand: Whirlpool   Age: 5 - 10 years
My washer has power, but no command. Replaced the control board and didn't fix anything, what a waste of money. i need help please.
Ads By Google
Related Models
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
Frigidaire GWS223RHS0 Gib(v0) / Washer
Frigidaire GWS223RHS1
Frigidaire GWS445RFS0 Gib(v0) / Washer
Frigidaire GWS445RFS1 Gib(v1)
Frigidaire GWS445RFS2 Gib(v0) / Washer
Frigidaire GWS445RHS0 Gib(v0) / Washer
Gibson GWS445RHS1 Washer - Gibson
Frigidaire GWS645RBS0 Gib(v0) / 27 " Washer
Frigidaire GWS645RBS1 Gib(v0) / Washer
Frigidaire GWS645RBS2 Gib(v0) / Washer
Frigidaire GWS645RBS3 Gib(v0) / Washer
Frigidaire GWS645RBS4 Gib(v0) / Washer
Frigidaire GWS645RFS0 Gib(v0) / Washer
Frigidaire GWS645RFS1 Gib(v0) / Washer
Frigidaire GWS645RFS2 Gib(v0) / Washer
Frigidaire GWS645RHS0 Gib(v0) / Washer
Gibson GWS645RHS1 Washer - Gibson
Gibson GWS833CS0 Gibson/washer
General Electric GWSE5240H0WW Washer
Gibson GWT1149AS0 Washer - Gibson
Gibson GWT1749AS0 Washer - Gibson
Frigidaire GWT445RFS0 Gib(v0) / Washer
Frigidaire GWT445RFS1 Gib(v0) / Washer
Frigidaire GWT445RFS2 Gib(v0) / Washer
Frigidaire GWT445RGS0 Gib(v0) / Washer
Frigidaire GWT445RGS1 Gib(v0) / Washer
Frigidaire GWT445RGS2 Gib(v0) / Washer
Frigidaire GWT645RHS0 Gib(v0) / Front Load Washer
Gibson GWTR645RHS0 Gibson/washer / Front Load Washer
Frigidaire GWV19W
Frigidaire GWX223RBD1 Gib(v1) / 27 " Washer
Frigidaire GWX223RBD3 Gib(v1) / Washer
  #2 (permalink)
Old 12-28-2012, 11:43 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Normally replacing the control unit should have fixed this, and if you purchased from this site you can return the control unit.
The first thing you need to do is to test to see that you have 120v going to the control unit, and if so then check each of the connections and wires coming from the control unit. You may have a short, or a broken wire, and it may be broken internally so you will have to test each wire for continuity.
Good luck, hope this helps.
__________________
  #3 (permalink)
Old 01-01-2013, 07:00 AM
Junior Member
Default Still nothing
I have 120v going to the new control board have power as far as p16 circut also check the door switch which check out also. Again thanks for trying to help. David
  #4 (permalink)
Old 01-01-2013, 07:06 AM
Senior Expert
APP Volunteer
Default
This is somewhat of a mystery, not sure what the problem is.
See if where you purchased the board from will exchange it,but it is not likely the replacement board is the problem.
__________________
  #5 (permalink)
Old 01-18-2013, 09:21 AM
Junior Member
Smile Fixed it !!!!
After i replaced the control board and it did the exact thing i went further thinking i check just about everything. Found a tech sheet inside the washer by mistake. I thought there should have been one but were. Anyway went throug the diag. I tested the control panel not the control board and the vaules of that board and they were off. Purchase a conyrol panel from APP and it works just fine.
Thanks for the help and the time you took out for me.
David
  #6 (permalink)
Old 01-18-2013, 10:27 AM
Senior Expert
APP Volunteer
Default
Great, glad you got it fixed and thanks for the update with the info. That will be very helpful to people who view this Forum.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
