| » Washer fills w/water and thats it. |
Model Number: 110.82881800 Brand: Kenmore Age: More than 10 years
Washer fills with water and then just sits. No noise, nothing. Changed water lever to high and it will fill but nothing else. No spinning, pumping out, nothing. Just sits quietly. Ideas?
Thanks! Ads By Google Related Models |
That's a very old model (22 yrs?). In the old models, the lid switch generally only affected drain/spin mode. Will it drain and spin if you manually advance the timer? If it drains and spins ok, I would check the water level pressure switch. Since the water does shut off, it is activating but the full position may be defective which would prevent agitation and timer movement.
Eric |
| Display Modes | |
| Washer Fills With Water On Its Own | metroid16 | Washer Repair | 3 | 06-13-2012 12:54 AM |
| Washer only fills with hot water, no water during rinse cycle | rcmedrec1 | Washer Repair | 1 | 08-05-2011 06:28 PM |
| Washer fills with water when OFF | tballard | Washer Repair | 1 | 02-19-2010 06:33 PM |
| Washer fills with water and then nothing | mamabotanica | Washer Repair | 1 | 08-06-2009 09:32 AM |
| washer fills with water but does nothing after that | threads68 | Washer Repair | 0 | 06-06-2008 01:59 PM |
