Discuss
washer will not fill
 in
Washer Repair
My washer will not fill with water. When I add water to it from a hose, the machine will go
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not fill
  #1 (permalink)
Old 12-24-2012, 02:23 PM
Junior Member
KarenSep is on a distinguished road
Default washer will not fill
Model Number: LA79700AAW   Brand: Maytag   Age: More than 10 years
My washer will not fill with water. When I add water to it from a hose, the machine will go through it's cycles until it gets to the rinse cycle and then I have to use the hose to fill it up again. I am guessing that the water valve needs to be replaced. Could I be right?
Ads By Google
Related Models
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 Washer - Top Loading
Maytag LA806S Washer - Top Loading
Maytag LA810 Washer - Top Loading
Maytag LA8100 Washer - Top Loading
Whirlpool LA8100XWW0
Whirlpool LA8100XWW1
Maytag LA8120 Washer - Top Loading
Maytag LA8140 Washer - Top Loading
Maytag LA8200 Washer - Top Loading
Whirlpool LA8200XWW0
Whirlpool LA8200XWW1
Maytag LA8210 Washer - Top Loading
Maytag LA8240 Washer - Top Loading
Maytag LA8340 Washer - Top Loading
Amana LA83830.A Mwave - Family Size (60 Hz)
Whirlpool LA8400XWF0
Whirlpool LA8400XWF1
Whirlpool LA8400XWG0
Whirlpool LA8400XWG1
Whirlpool LA8400XWM0
Whirlpool LA8400XWM1
Whirlpool LA8400XWN0
Whirlpool LA8400XWN1
Whirlpool LA8400XWW0
Whirlpool LA8400XWW1
Maytag LA8420 Washer - Top Loading
Maytag LA8440 Washer - Top Loading
Maytag LA8500 Washer - Top Loading
Maytag LA8520 Washer - Top Loading
Whirlpool LA8580XWF0
Whirlpool LA8580XWF1
Whirlpool LA8580XWF2
Whirlpool LA8580XWG0
Whirlpool LA8580XWG1
Whirlpool LA8580XWG2
Whirlpool LA8580XWM0
Whirlpool LA8580XWM1
Whirlpool LA8580XWM2
Whirlpool LA8580XWN0
Whirlpool LA8580XWN1
Whirlpool LA8580XWN2
Whirlpool LA8580XWW0
Whirlpool LA8580XWW1
Whirlpool LA8580XWW2
Maytag LA8600 Washer - Top Loading
Maytag LA8640 Washer - Top Loading
Maytag LA8650 Washer - Top Loading
Maytag LA8700 Washer - Top Loading
Maytag LA8740 Washer - Top Loading
Maytag LA8800 Washer - Top Loading
Whirlpool LA8800XSW0
Whirlpool LA8800XSW1
Whirlpool LA8800XSW2
Whirlpool LA8800XTF0
Whirlpool LA8800XTF1
Whirlpool LA8800XTG0
Whirlpool LA8800XTG1
Whirlpool LA8800XTM0
Whirlpool LA8800XTM1
Whirlpool LA8800XTN0
Whirlpool LA8800XTN1
Whirlpool LA8800XTW0
Whirlpool LA8800XTW1
Maytag LA882 Washer - Top Loading
Maytag LA8820 Washer - Top Loading
Maytag LA882T Washer - Top Loading
Maytag LA883 Washer - Top Loading
Maytag LA883T Washer - Top Loading
Maytag LA884 Washer - Top Loading
Maytag LA8840 Washer - Top Loading
Whirlpool LA8860XWQ0
Maytag LA902 Washer - Top Loading
Whirlpool LA9100XTF0
Whirlpool LA9100XTF1
Whirlpool LA9100XTG0
Whirlpool LA9100XTG1
Whirlpool LA9100XTM0
Whirlpool LA9100XTM1
Whirlpool LA9100XTN0
Whirlpool LA9100XTN1
Whirlpool LA9100XTW0
Whirlpool LA9100XTW1
Maytag LA9200 Washer - Top Loading
Maytag LA9200D Washer - Top Loading
Whirlpool LA9200XWF0
Whirlpool LA9200XWF1
Whirlpool LA9200XWG0
Whirlpool LA9200XWG1
Whirlpool LA9200XWM0
Whirlpool LA9200XWM1
Whirlpool LA9200XWN0
Whirlpool LA9200XWN1
Whirlpool LA9200XWW0
Whirlpool LA9200XWW1
Maytag LA9300 Washer - Top Loading
Whirlpool LA9300XTF0
Whirlpool LA9300XTF1
Whirlpool LA9300XTG0
Whirlpool LA9300XTG1
Whirlpool LA9300XTM0
Whirlpool LA9300XTM1
  #2 (permalink)
Old 12-24-2012, 04:39 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Please, provide the correct model number. This one doesn't come up.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-24-2012, 09:10 PM
Junior Member
Default
Should be Model #LAT9700AAW
  #4 (permalink)
Old 12-25-2012, 07:54 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
There is a fuse in the lid switch assembly that will blow if the lid switch fails. This prevents the washer from filling. If the fuse is blown, you can just temporalily jump it out. It is not there for circuit protection. It's only function is to render the washer inoperable (can't fill) in the event the lid switch fails in the closed position. If it's the fuse, just replace the whole lid switch assembly. The assembly includes a new lid switch, lid check switch and fuse/fuseholder. The switch is located under the control panel.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Will Not Fill dcoile72 Washer Repair 2 02-09-2012 11:10 AM
Washer will not fill after replacing fill valve toddf Washer Repair 1 12-03-2010 12:39 PM
Washer won't fill Diana Banana Washer Repair 4 01-05-2009 07:36 AM
washer will fill but won't run tltakj Washer Repair 1 06-17-2008 03:49 AM
Washer will not fill up pssndwy Washer Repair 1 10-24-2007 08:54 PM
