| » Washer Spin Cycle Very Loud |
Model Number: MAH5500BWW Brand: Maytag Age: 5 - 10 years
My washer has developed to be a very loud monster from the quite mouse it used to be. Mostly notice the loudness during the spin cycle and it is really loud using Max Extract. I suspect a bearing gone bad but have no parts manual but only my own mechanical experience with bad bearings on other mechanical devices throughout my life. Any light you can shed on this problem I do appreciate it.
I spoke with one of your parts techs and he told me to jump on this forum to find out what parts I may need to correct this problem. Thanks Much. Ads By Google Related Models |
Quote:
Part number: 22002934 Part number: 22003441 Part number: 12002022 Part number: 22004465
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I dropped the ball on getting this washer fixed and now it is only get worse. I wanted to validate these parts you pointed me to becuase when I looked up the bearings on your web site and they do not corelate to my Maytag MAH5500BWW. Kind of figured you and your team had some inside understanding to the use of these parts over and above what the web site shows but wanted to make sure of that.
Could you please validate that the bearings are the correct part numbers? Don't think I want to replace the whole tub just for the bearings. And I saw that the Lip seal kit matched up with this machine on your site. Thanks Much. Dale |
I have same model, just finished bearing replacement. Took about 3 hours, pretty involved. Might want to replace the spinner support (part# 22003925) cost $100, but comes with lip gasket which is $40 itself. New support has revised seal design to (supposedly) eliminate this problem in future. We'll see.
I have a pdf repair manual, tech bulletin (spinner support), photos, and repair process. Was given to me, will pass it on no charge. If interested message me at contractorkev44@yahoo.com |
Quote:
I was just curious if you ended up switching the bearings, and if those part numbers were correct for your model of washer. Thanks! |
| Display Modes | |
| Washer makes loud noise at end of spin cycle | HVAC pirate | Washer Repair | 1 | 02-24-2010 05:28 PM |
| washer loud spin cycle | rottweiler | Washer Repair | 4 | 01-10-2010 09:09 AM |
| Loud squeal at spin cycle then washer stops. | tstroutt | Washer Repair | 3 | 08-04-2009 03:15 PM |
| Washer makes a loud clicking noise on spin cycle | pattihanni | Washer Repair | 0 | 05-02-2009 09:40 AM |
| Washer makes loud clicks during spin cycle | joycejeff2 | Washer Repair | 1 | 02-16-2009 01:53 PM |
