Discuss
Hotpoint washer can stop motor by hand
 in
Washer Repair
This washer agitates correctly.....but sometimes will not spin. When It fails To spin, I can start it spinning by hand
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Hotpoint washer can stop motor by hand
  #1 (permalink)
Old 12-20-2012, 05:56 PM
Member
Nitro itch is on a distinguished road
Default Hotpoint washer can stop motor by hand
Model Number: VBXR1090D0WW   Brand: Hotpoint   Age: 5 - 10 years
This washer agitates correctly.....but sometimes will not spin. When It fails To spin, I can start it spinning by hand andnitbill get up to normal high speed spinning. Yet I can hold the drum from turning easily....
And when I do, the motor stops without any loud noise...and it does not draw any more amps ( monitoring it with amp probe inductive meter) standing still with no turning, as it does with it spinning the empty drum at full speed. In other words, I can stop the drum from spinning, with one hand and the motor doesn't turn or belt slip. It's like a very weak motor. But it does not hum or heat up or trip the breaker.
Related Models
General Electric VBXR1090D0WW Washer
General Electric VBXR1090D1WW Washer
General Electric VBXR1090D2CC Washer
General Electric VBXR1090D2WW Washer
General Electric VBXR1090D3WW Washer
General Electric VBXR1090D4WW Washer
General Electric VBXR1090D5CC Washer
General Electric VBXR1090D5WW Washer
General Electric VBXR1090D6WW Washer
General Electric VBXR1090D7WW Washer
General Electric VBXR1090D8CC Washer
General Electric VBXR1090D8WW Washer
General Electric VBXR1090D9WW Washer
General Electric VBXR1090DACC Washer
General Electric VBXR1090DAWW Washer
General Electric VBXR1090DBCC Washer
General Electric VBXR1090DBWW Washer
General Electric VBXR1090DDCC Washer
General Electric VBXR1090DDWW Washer
General Electric VBXR2070T2AB Washer
General Electric VBXR2070T2WB Washer
General Electric VBXR2070T3AB Washer
General Electric VBXR2070T3WB Washer
General Electric VBXR2070T5AB Washer
General Electric VBXR2070T5WB Washer
General Electric VBXR2070T6AB Washer
General Electric VBXR2070T6WB Washer
General Electric VBXR2070T8AB Washer
General Electric VBXR2070T8WB Washer
General Electric VBXR2070TAAB Washer
General Electric VBXR2070TAWB Washer
General Electric VBXR2070V0AA Washer
General Electric VBXR2070V0WW Washer
General Electric VBXR2070V1AA Washer
General Electric VBXR2070V1WW Washer
Thermador VC-500
Gaggenau VC112-602
Gaggenau VC113-602
Gaggenau VC114-602
Gaggenau VC116-602
Gaggenau VC230-612
Gaggenau VC343-602
Gaggenau VC345-602
Gaggenau VC355-602
Thermador VCH-2 CONTROL HOUSING
Thermador VCH-3 RANGE HOOD
Thermador VCH-6 CONTROL HOUSING
Thermador VCH-6A CONTROL HOUSING
Thermador VCH-7 CONTROL HOUSING
Thermador VCH-7A CONTROL HOUSING
Thermador VCH-8 CONTROL HOUSING
Thermador VCH-9 CONTROL HOUSING
Amana VCH3 ELE CARTRIDGE
Thermador VCH36
Amana VCH4 ELE CARTRIDGE
Thermador VCH54
Thermador VCK-1 VENTILATOR
Thermador VCK-1A RANGE HOOD
Thermador VCK-300
Bosch VD030-000
Bosch VD030-010
Bosch VD030-099
Bosch VD040-000
Bosch VD040-010
Bosch VD040-099
Bosch VD050-010
Gaggenau VE112-612
Frigidaire VE21AW5 Tap(v1) / Electric Range
Amana VE3013 WASHER-TOP LOADING
Frigidaire VE30AW5 Tap(v1) / Electric Range
Frigidaire VE30BW4 Tap(v1) / Electric Range
Frigidaire VE30CW4 Tap(v1) / Electric Range
Gaggenau VE313-613
Amana VE5013 WASHER-TOP LOADING
Amana VEND-10.000 COMMERCIAL MICROWAVES
Amana VEND-10.A COMMERCIAL MICROWAVES
Amana VEND-10.B COMMERCIAL MICROWAVES
Amana VEND-10.C COMMERCIAL MICROWAVES
Amana VEND-10.F COMMERCIAL MICROWAVES
Amana VEND-10.G COMMERCIAL MICROWAVES
Amana VEND-10.H COMMERCIAL MICROWAVES
Amana VEND-10.J COMMERCIAL MICROWAVES
Amana VEND-7.003 COMMERCIAL MICROWAVES
Amana VEND-7.004 COMMERCIAL MICROWAVES
Amana VEND-7.005 COMMERCIAL MICROWAVES
Amana VEND-7.A COMMERCIAL MICROWAVES
Amana VEND-7.B COMMERCIAL MICROWAVES
Amana VEND-7D.001 COMMERCIAL MICROWAVES
Amana VEND-7D.A COMMERCIAL MICROWAVES
Amana VEND10 COMMERCIAL MICROWAVES
Amana VEND11 COMMERCIAL MICROWAVES
Amana VEND11B COMMERCIAL MICROWAVES
Hoover VER1360AGH RANGE- F/S STD ELE
Gaggenau VF112-610
Gaggenau VF230-610
Gaggenau VF332-610
Frigidaire VG21AW3 Tap(v1) / Gas Range
Frigidaire VG21AW3-23 Tap(v2) / Gas Range
Gaggenau VG223-812
Gaggenau VG230-811
Gaggenau VG231-211CA
Gaggenau VG232-212CA
Amana VG3019 WASHER-TOP LOADING
Frigidaire VG30AW3 Tap(v1) / Gas Range
Frigidaire VG30AW3-23 Tap(v2) / Gas Range
Frigidaire VG30BW2 Tap(v1) / Gas Range
Frigidaire VG30BW2-23 Tap(v2) / Gas Range
Frigidaire VG30CW2 Tap(v1) / Gas Range
Frigidaire VG30CW2-23 Tap(v2) / Gas Range
Gaggenau VG330-811
Gaggenau VG352-812
Gaggenau VG353-112
Gaggenau VG353-212
Frigidaire VG36DW2 Tap(v1) / Gas Range
Frigidaire VG36DW2-23 Tap(v2) / Gas Range
Amana VG5019 WASHER-TOP LOADING
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
  #2 (permalink)
Old 12-20-2012, 06:41 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Check the voltage at the motor when running normally and again when you have it stopped by holding the tub. Check for 120vac across the blue and yellow wires as well as across the red and violet/white wires. If there is no significant voltage drop, you might try replacing the capacitor behind the control panel. This is a PCS motor so the capacitor is in use for both starting and running. If you have a voltage drop problem at the motor, you need to look for bad connections in the wiring or possibly a bad lid switch or timer (bad contacts).
Eric
  #3 (permalink)
Old 12-20-2012, 07:16 PM
Member
Default
Can't get to machine just now, but I o recall a capacitor mounted on back panel of washer midway down with two red wires attached anyone of them going down to motor. Yet I just looked at the illustrated parts diagrams shown here at this site, and it appears there are two capacitors with the same part number shown....one as I saw....and one listed with the console and controls. Is this correct, two capacitors, same part number, one above in controls and the other down ner the motor? The lid switch has been bypass since the top is off. What is a PCS MOTOR? I have seen motors on other equipment have a bad start capacitor which cause the motor to not rotate,,,,,but ,,,the motor would make a loud humming sound and eventually trip the overload. This motor when stalled only draws approx 2.7 amps if I recall correctly, which is not more than when it's spinning the empty tub at full speed.
  #4 (permalink)
Old 12-20-2012, 08:30 PM
Expert
APP Volunteer
Default
Yes, I see now that there are two capacitors. I don't have the tech sheet for that specific model. The tech sheet should be behind the control panel. Would be good if you could post a clear pic of it. I meant PSC motor which stands for permanent split capacitor which is same as capacitor start capacitor run. It means the capacitor is used for starting but remains in circuit during run as well. There is no centrifugal switch in the motor to disconnect the start winding. Not 100% sure about your washer, the tech sheet I was looking at is not exact one for your model. I believe yours is tech sheet 31-15551
Can't say for sure without schematic, but I'm thinking this may be a true capacitor start capacitor run motor that uses two capacitors and centrifugal switch. During starting, the two capacitors are in parallel providing higher starting torque and then one is switched out by the centrifugal switch after motor is up to speed and then the other capacitor is used alone with the run winding. If there is no voltage drop issue, I would try replacing both capacitors. They are the same size.
Well, got a copy of mini-manual 31-15551 and it only shows one capacitor, no centrifugal switch in motor so it's a PSC. Maybe 31-15551 is not the right manual for this washer. You'll have to check the one behind the control panel.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't agitate or spin, can turn motor by hand englaisfitz Washer Repair 23 11-14-2014 07:41 AM
HotPoint dryer won't stop baackg Dryer Repair 0 12-15-2008 09:30 AM
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor bluestreak Washer Repair 12 12-06-2008 01:53 AM
