Discuss
is my motor fried?
 in
Washer Repair
Washer quit spinning, agitating, and draining. It made a loud buzzing noise for about 90 seconds and started to get
Appliance Repair Forum > Appliance Repair Help > Washer Repair » is my motor fried?
  #1 (permalink)
Old 12-20-2012, 07:02 AM
Junior Member
krinton is on a distinguished road
Question is my motor fried?
Model Number: 11082670110   Brand: Kenmore   Age: 1 - 5 years
It made a loud buzzing noise for about 90 seconds and started to get hot/smell, then shut off.
I opened her up and found an obstruction in the pump and saw that the impeller was shredded, but when I took off the motor, saw that the coupler was fine - no crumbled bits of rubber, no visible fatigue in the two plastic pieces.
I bypassed the lid switch so I can operate the machine without the housing attached, and better diagnose the issue.
Now when I switch her on in spin or agitate, the buzzing starts but nothing happens in the drive motor (except it gets really hot).
When I manually give the drive shaft a slight twist, that seems to get things going, and the motor starts spinning as it should.
SO... do I have a bad drive motor? It looks like those will run around $150 - better to just plunk down $400 on a new unit?
Ads By Google
Related Models
Kenmore 1108271972 BRAKE AND DRIVE TUBE
Kenmore 11083074130 WASHER
Kenmore 11083074230 WASHER
Kenmore 11083074430 WASHER
Kenmore 11083074630 WASHER
Kenmore 11083074830 WASHER
Kenmore 11083075120 SEARS ELECTRIC WASHER
Kenmore 11083075220 SEARS ELECTRIC WASHER
Kenmore 11083075420 SEARS ELECTRIC WASHER
Kenmore 11083075620 SEARS ELECTRIC WASHER
Kenmore 11083075820 SEARS ELECTRIC WASHER
Kenmore 11083150100 SEARS ELECTRIC WASHER
Kenmore 11083150110 SEARS ELECTRIC WASHER
Kenmore 11083151110 SEARS ELECTRIC WASHER
Kenmore 11083170100 SEARS ELECTRIC WASHER
Kenmore 11083170400 SEARS ELECTRIC WASHER
Kenmore 11083170600 SEARS ELECTRIC WASHER
Kenmore 11083170800 SEARS ELECTRIC WASHER
Kenmore 11083171110 SEARS ELECTRIC WASHER
Kenmore 11083171410 SEARS ELECTRIC WASHER
Kenmore 11083171610 SEARS ELECTRIC WASHER
Kenmore 11083171810 SEARS ELECTRIC WASHER
Kenmore 11083172100 SEARS ELECTRIC WASHER
Kenmore 11083172110 SEARS ELECTRIC WASHER
Kenmore 11083172130 WASHER
Kenmore 11083172200 SEARS ELECTRIC WASHER
Kenmore 11083172210 SEARS ELECTRIC WASHER
Kenmore 11083172230 WASHER
Kenmore 11083172400 SEARS ELECTRIC WASHER
Kenmore 11083172410 SEARS ELECTRIC WASHER
Kenmore 11083172430 WASHER
Kenmore 11083172600 SEARS ELECTRIC WASHER
Kenmore 11083172610 SEARS ELECTRIC WASHER
Kenmore 11083172630 WASHER
Kenmore 11083172800 SEARS ELECTRIC WASHER
Kenmore 11083172810 SEARS ELECTRIC WASHER
Kenmore 11083172830 WASHER
Kenmore 1108318272 GAS BURNER
Kenmore 1108318276 GAS BURNER
Kenmore 11083194100 SEARS ELECTRIC WASHER
Kenmore 11083194110 SEARS ELECTRIC WASHER
Kenmore 11083194120 SEARS ELECTRIC WASHER
Kenmore 11083194140 SEARS ELECTRIC WASHER
Kenmore 11083194200 SEARS ELECTRIC WASHER
Kenmore 11083194210 SEARS ELECTRIC WASHER
Kenmore 11083194220 SEARS ELECTRIC WASHER
Kenmore 11083194240 SEARS ELECTRIC WASHER
Kenmore 11083194400 SEARS ELECTRIC WASHER
Kenmore 11083194410 SEARS ELECTRIC WASHER
Kenmore 11083194420 SEARS ELECTRIC WASHER
Kenmore 11084050100 AUTOMATIC WASHER
Kenmore 11084050110 AUTOMATIC WASHER
Kenmore 11084050120 AUTOMATIC WASHER
Kenmore 11084070100 AUTOMATIC WASHER
Kenmore 11084070110 AUTOMATIC WASHER
Kenmore 11084070120 AUTOMATIC WASHER
Kenmore 11084070800 AUTOMATIC WASHER
Kenmore 11084070810 AUTOMATIC WASHER
Kenmore 11084070820 AUTOMATIC WASHER
Kenmore 11084090100 AUTOMATIC WASHER
Kenmore 11084090110 AUTOMATIC WASHER
Kenmore 11084090120 AUTOMATIC WASHER
Kenmore 11084090130 AUTOMATIC WASHER
Kenmore 11084090200 AUTOMATIC WASHER
Kenmore 11084090210 AUTOMATIC WASHER
Kenmore 11084090220 AUTOMATIC WASHER
Kenmore 11084090230 AUTOMATIC WASHER
Kenmore 11084090400 AUTOMATIC WASHER
Kenmore 11084090410 AUTOMATIC WASHER
Kenmore 11084090420 AUTOMATIC WASHER
Kenmore 11084090430 AUTOMATIC WASHER
Kenmore 11084090600 AUTOMATIC WASHER
Kenmore 11084090610 AUTOMATIC WASHER
Kenmore 11084090620 AUTOMATIC WASHER
Kenmore 11084090630 AUTOMATIC WASHER
Kenmore 11084090800 AUTOMATIC WASHER
Kenmore 11084090810 AUTOMATIC WASHER
Kenmore 11084090820 AUTOMATIC WASHER
Kenmore 11084090830 AUTOMATIC WASHER
Kenmore 11084350100 ELECTRIC WASHER
Kenmore 11084370100 ELECTRIC WASHER
Kenmore 11084370110 ELECTRIC WASHER
Kenmore 11084370800 ELECTRIC WASHER
Kenmore 11084370810 ELECTRIC WASHER
Kenmore 11084390100 ELECTRIC WASHER
Kenmore 11084390110 ELECTRIC WASHER
Kenmore 11084390200 ELECTRIC WASHER
Kenmore 11084390210 ELECTRIC WASHER
Kenmore 11084390300 ELECTRIC WASHER
Kenmore 11084390310 ELECTRIC WASHER
Kenmore 11084390400 ELECTRIC WASHER
Kenmore 11084390410 ELECTRIC WASHER
Kenmore 11084390600 ELECTRIC WASHER
Kenmore 11084390610 ELECTRIC WASHER
Kenmore 11085155100 SEARS ELECTRIC WASHER
Kenmore 11085156100 SEARS ELECTRIC WASHER
Kenmore 11085165100 SEARS ELECTRIC WASHER
Kenmore 11085165400 SEARS ELECTRIC WASHER
Kenmore 11085165600 SEARS ELECTRIC WASHER
Kenmore 11085165800 SEARS ELECTRIC WASHER
Kenmore 11085166100 ELECTRIC WASHER
Kenmore 11085175100 SEARS ELECTRIC WASHER
Kenmore 11085175200 SEARS ELECTRIC WASHER
Kenmore 11085175400 SEARS ELECTRIC WASHER
Kenmore 11085175600 SEARS ELECTRIC WASHER
Kenmore 11085175800 SEARS ELECTRIC WASHER
Kenmore 11085185100 SEARS ELECTRIC WASHER
Kenmore 11085185400 SEARS ELECTRIC WASHER
Kenmore 11085185600 SEARS ELECTRIC WASHER
Kenmore 11085185800 SEARS ELECTRIC WASHER
Kenmore 11085257100 ELECTRIC WASHER
Kenmore 11085365100 WASHER
Kenmore 11085365200 WASHER
Kenmore 11085365400 WASHER
Kenmore 11085365600 WASHER
Kenmore 11085365800 WASHER
Kenmore 11086070200 ELECTRIC DRYER
Kenmore 11086070210 ELECTRIC DRYER
Kenmore 11086070400 ELECTRIC DRYER
Kenmore 11086070410 ELECTRIC DRYER
  #2 (permalink)
Old 12-20-2012, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
The motor has gone bad and has to be replaced. But, if the washer is in good condition it's probably worth to fix it.
Whirlpool does not make such washers anymore due to government regulations so, you can not buy a new machine with the same design. This design has been proven for almost 30 years and most of technicians will tell that this washer (direct drive) is one of the best American washers. It's also does not have any electronic parts which makes this machine more reliable.
- The motor Part number: 661600
Part number: 661600
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-20-2012, 01:53 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
The start capacitor may have been damaged as it is only meant to be energized for less than a second as the motor starts. After that, it is switched out of the circuit by the centrifugal switch in the motor. With the motor jammed by the pump, it had power to it continuously, long enough for the motor overload to trip. Since you can start the motor by hand, the motor may be ok. I would try replacing the capacitor first. They are usually mounted on the motor but looks like on this model, it is behind the control panel. You might also check the resistance of the start winding of the motor to make sure it wasn't burnt open. Unplug the wiring harness from the motor and on the motor switch check between the black and yellow wires. It should read between 4-7 ohms. If it's ok, try a new capacitor. You can get a perfectly suitable substitute at Grainger for $6.31 Part number 2MDR5 I agree 100% about spending the money to fix your washer vice buying one of the new pieces of junk they are selling now.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Smelled like motor fried..now it's fine? houndman Washer Repair 1 10-14-2011 06:27 PM
Motor Fried? nick t. Washer Repair 1 03-29-2011 06:29 PM
Dryer motor fried? cobigcheese Dryer Repair 2 09-10-2010 02:22 PM
Whirlpool motor control board fried (pictures) rharder Washer Repair 3 02-19-2010 02:58 PM
Fried ??? KeithGoss Refrigerator & Freezer Repair 0 01-15-2009 08:26 AM
