| » spin only |
Model Number: mvwc6esww1 Brand: Maytag Age: 1 - 5 years
not sure of the age serial # cy4944762 Can you tell me?My problem is my washer will only spin in the spin cycle.When i put the timer in any other position nothing happens.The timer won't move eather. I have ordered a new timer but not sure if that will fix it/ What do you think?
Manufactured in Nov 09. Likely has a bad load sense switch. If that is what it turns out to be, complain loudly to Whirlpool. It is a VERY high failure item on this machine and others that use that switch.
Eric Last edited by fairbank56 : 12-19-2012 at 08:10 PM. |
Quote:
Thanks for your help. |
http://www.whirlpool.com/contact-us/
Maytag was aquired by Whirlpool in 2006. Keep your receipts, don't be suprised when you have to replace that switch again. Eric |
| Display Modes | |
| my kenmore washer makes a grinding noise during spin cycle and does not spin | bronco48 | Washer Repair | 2 | 10-28-2012 02:42 AM |
| Front load washer won't spin water out of clothes on last spin cycle | Tracey Finley | Washer Repair | 1 | 06-28-2011 05:10 PM |
| motor, belt & trans pully spin, no agitation/spin cycle | slavens | Washer Repair | 2 | 05-08-2010 04:10 PM |
| Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? | mikeal21 | Washer Repair | 1 | 03-01-2010 06:21 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
