Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer wont spin. (http://forum.appliancepartspros.com/washer-repair/511935-washer-wont-spin.html)
danielcastro3669 12-19-2012 01:51 PM
washer wont spin.
waher wont spin. the lid switch checks out ok. what else could it be?
fairbank56 12-19-2012 02:45 PM
Does it fill, agitate and drain? If it drains, does the motor pause after draining and then start again?
Eric
danielcastro3669 12-19-2012 07:12 PM
Quote:
Eric
it does fill agitate and drain, but i didn't notice if it paused after draining, but if it does what would it point out to be? thank you..
fairbank56 12-19-2012 08:16 PM
It is supposed to pause after draining. During the initial minute or two period of drain, it does not spin because the gearcase is in neutral drain mode. Pausing of the motor allows neutral drain to release. When it starts again, it should drain and spin. If it doesn't pause, you can do that manually by simply opening the lid for a few seconds and closing again. If this doesn't put it into spin, you will need to remove the cabinet, jump out the lid switch and observe the clutch operation during spin.
Eric
danielcastro3669 12-20-2012 02:37 PM
Quote:
Eric
the clutch makes a click noise, and its getting extremely hot..is the clutch incharge of engaging the spin mode? thank you eric. i've had this no spin problem before and it's always been the lid switch.
fairbank56 12-20-2012 03:58 PM
If the clutch is getting hot, then it is slipping. A tab on the clutch band engages the arm on the brake cam driver which releases the brakes and turns the basket drive tube. You need to pull the gearcase and rotate the brake cam driver by hand to see if it releases the brake and freely rotates the basket. If it releases the brake but is difficult or impossible to turn the basket, there may be clothing caught between the basket and outer tub.
Eric
danielcastro3669 12-21-2012 02:03 PM
Quote:
Eric
thanks eric, i will check for that. and will keep you posted on what i find.
