| » kenmore 110 agitation problem |
Model Number: 110 21882 Brand: Kenmore Age: More than 10 years
Hello everyone,
I have tried searching for this but with no luck. I have a kenmore 110 21882 washer that makes a strange noise when agitating and will not change agitation speeds. Agitation seems a little erratic. The agitation speed switch seems good, changed to very slow delicate and got correct behavior, with strange sound when agitating. The agitator dogs seem to work good; have some experience with these after replacing on another washer. Everything else seems fine. Tub will fill correctly, draining, spinning, timer all seem ok. I have successfully fixed the washer before when fill valve needed replacement. Thanks in advance. Ads By Google Related Models |
Agitation speed is controlled by the timer and motor.
You should be able to pin point the noise well running the washer with the cabinet off.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| Kenmore Agitation Problem | dfyfe | Washer Repair | 4 | 07-16-2012 04:52 PM |
| Kenmore Washer Agitation Problem | garyz | Washer Repair | 1 | 12-09-2009 06:57 AM |
| Agitation Problem | mrs54528 | Washer Repair | 1 | 10-26-2009 06:53 PM |
| Agitation problem | judithbenedict | Washer Repair | 1 | 05-14-2009 05:22 PM |
| Kenmore washer 110.28822790 agitation problem. | acillatem | Washer Repair | 1 | 03-07-2009 10:36 PM |
