Discuss
Washer stops filling after 5 seconds
 in
Washer Repair
I choose settings for my washer and hit start. It starts to fill for only 3 to 5 seconds and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer stops filling after 5 seconds
  #1 (permalink)
Old 12-18-2012, 07:20 PM
Junior Member
36chevy is on a distinguished road
Default Washer stops filling after 5 seconds
Brand: Frigidaire   Age: 1 - 5 years
I choose settings for my washer and hit start. It starts to fill for only 3 to 5 seconds and stops. I already changed the water valve with the solenoids. What should I do next?
Ads By Google
  #2 (permalink)
Old 12-18-2012, 08:53 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely the pressure switch is bad.
What is the model number?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-19-2012, 04:31 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
The model # is FAFW3577KW1 Frigidaire Affinity Washer
  #4 (permalink)
Old 12-19-2012, 04:34 AM
Junior Member
Default
Quote:
If it is the pressure switch, how do I disassemble the unit and where can I find the location of the pressure switch? Can I do a continuity test on the switch to see if it is bad or do I have to measure the resistance in ohms? If so, what should the resistance read? Thanks for your help.
  #5 (permalink)
Old 12-19-2012, 10:42 AM
Expert
Default
Hi.
Remove the top by taken out screws holding it from the back and sliding the top back and up.You should see the pressure switch on the right mounted to the frame
Part number: 134762000
If the contacts 1-2 are closed and water is not filling in - check the connection at the control board and replace it
Part number: 137007010
If the contacts are open - blow in to the air hose to clear it and if nothing change - replace the pressure switch.
Here are the breakdown diagrams and Control Panel parts for Frigidaire FAFW3577KW1 - AppliancePartsPros.com
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer stops after filling up cblevins Washer Repair 7 08-16-2012 10:04 AM
Washer stops while filling. Grawlt Washer Repair 0 01-14-2012 02:14 PM
washer stops before filling chrischr64 Washer Repair 1 07-13-2011 07:10 AM
GE Profile Washer only spins for 2 seconds, then stops, then smokes kurse Washer Repair 4 04-01-2009 05:53 PM
Washer fill stops after a few seconds BaldHeadedGuy Washer Repair 2 02-10-2009 04:47 PM
