Discuss
Kenmore Washer's Difficult Inner Basket Removal
 in
Washer Repair
Kenmore Washer's Difficult Inner Basket Removal We are trying to repair the leaks that are coming from the lower base
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer's Difficult Inner Basket Removal
  #1 (permalink)
Old 12-18-2012, 02:38 PM
Junior Member
Jim Saad is on a distinguished road
Default Kenmore Washer's Difficult Inner Basket Removal
Model Number: 1104830882   Brand: Kenmore   Age: More than 10 years
We are trying to repair the leaks that are coming from the lower base of the outer metal basket or drum in our Kenmore washer and we have been following the steps to do so; however, after having removed the agitator, and the nut from the drive block we are finding it extremely difficult to remove the inner basket from the metal drum or basket so that we can remove the drive block. It is simply seized. We tried tapping the stem of the inner basket with a hammer, using penetrating oil to loosen the inner basket's stem from around the drive block and still it will not move. We would like someone to give us some advice on what we can do in this case. Please note that when we examined the inner basket's stem, a few inches bellow the top of the opening where the drive block's nut is located we noticed that there are two holes on the stem, opposite one to another and they are covered with rubber plugs. Nobody can tell me the purpose of the holes. Thank you for your help.
Jim
Ads By Google
Related Models
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11049962600 WASHER
Kenmore 11049962601 RESIDENTIAL WASHER
Kenmore 11049962602 RESIDENTIAL WASHER
Kenmore 11049962603 RESIDENTIAL WASHER
Kenmore 11049972600 RESIDENTIAL WASHER
Kenmore 11049972601 RESIDENTIAL WASHER
Kenmore 11049972602 RESIDENTIAL WASHER
Kenmore 11049972603 RESIDENTIAL WASHER
Kenmore 1105062110 WASHER
Kenmore 110508802 KENMORE ELECTRIC DRYER
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 1105801100 KENMORE WRINGER WASHER
Kenmore 1105801200 KENMORE WRINGER WASHER
Kenmore 1105802301 KENMORE WRINGER WASHER
Kenmore 1105802330 KENMORE WRINGER WASHER
Kenmore 1105802331 KENMORE WRINGER WASHER
Kenmore 1105802400 KENMORE WRINGER WASHER
Kenmore 1105802600 KENMORE WRINGER WASHER
Kenmore 1105802601 KENMORE WRINGER WASHER
Kenmore 1105802700 KENMORE WRINGER WASHER
Kenmore 1105802701 KENMORE WRINGER WASHER
Kenmore 1105802800 KENMORE WRINGER WASHER
Kenmore 1105802801 KENMORE WRINGER WASHER
Kenmore 1105802901 KENMORE WRINGER WASHER
Kenmore 1105802910 KENMORE WRINGER WASHER
Kenmore 1105803000 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1105804100 KENMORE AUTOMATIC WASHER
Kenmore 1105804200 KENMORE AUTOMATIC WASHER
Kenmore 1105804201 KENMORE AUTOMATIC WASHER
Kenmore 1105804202 KENMORE AUTOMATIC WASHER
Kenmore 1105804203 KENMORE AUTOMATIC WASHER
Kenmore 1105804300 KENMORE AUTOMATIC WASHER
Kenmore 1105804301 KENMORE AUTOMATIC WASHER
Kenmore 1105804302 KENMORE AUTOMATIC WASHER
Kenmore 1105804303 KENMORE AUTOMATIC WASHER
Kenmore 1105804500 KENMORE AUTOMATIC WASHER
Kenmore 1105804501 KENMORE AUTOMATIC WASHER
Kenmore 1105804550 KENMORE AUTOMATIC WASHER
Kenmore 1105804551 KENMORE AUTOMATIC WASHER
Kenmore 1105804700 KENMORE AUTOMATIC WASHER
Kenmore 1105804702 KENMORE AUTOMATIC WASHER
Kenmore 1105804750 KENMORE AUTOMATIC WASHER
Kenmore 1105804752 KENMORE AUTOMATIC WASHER
Kenmore 1105804800 KENMORE AUTOMATIC WASHERS
Kenmore 1105804801 KENMORE AUTOMATIC WASHER
Kenmore 1105804802 KENMORE AUTOMATIC WASHER
Kenmore 1105804803 KENMORE AUTOMATIC WASHER
Kenmore 1105804804 KENMORE AUTOMATIC WASHER
Kenmore 1105804850 KENMORE AUTOMATIC WASHERS
Kenmore 1105804851 KENMORE AUTOMATIC WASHER
Kenmore 1105804852 KENMORE AUTOMATIC WASHER
Kenmore 1105804853 KENMORE AUTOMATIC WASHER
Kenmore 1105804854 KENMORE AUTOMATIC WASHER
Kenmore 1105804950 KENMORE AUTOMATIC WASHER
Kenmore 1105804951 KENMORE AUTOMATIC WASHER
Kenmore 1105804952 KENMORE AUTOMATIC WASHER
Kenmore 1105804953 KENMORE AUTOMATIC WASHER
Kenmore 1105805100 KENMORE AUTOMATIC WASHER
Kenmore 1105805200 KENMORE AUTOMATIC WASHER
Kenmore 1105805201 KENMORE AUTOMATIC WASHER
Kenmore 1105805202 KENMORE AUTOMATIC WASHER
Kenmore 1105805203 KENMORE AUTOMATIC WASHER
Kenmore 1105805300 KENMORE AUTOMATIC WASHER
Kenmore 1105805301 KENMORE AUTOMATIC WASHER
Kenmore 1105805302 KENMORE AUTOMATIC WASHER
Kenmore 1105805303 KENMORE AUTOMATIC WASHER
Kenmore 1105805500 KENMORE AUTOMATIC WASHER
Kenmore 1105805501 KENMORE AUTOMATIC WASHER
Kenmore 1105805550 KENMORE AUTOMATIC WASHER
Kenmore 1105805551 KENMORE AUTOMATIC WASHER
Kenmore 1105805700 KENMORE AUTOMATIC WASHER
Kenmore 1105805702 KENMORE AUTOMATIC WASHER
Kenmore 1105805750 KENMORE AUTOMATIC WASHER
Kenmore 1105805752 KENMORE AUTOMATIC WASHER
Kenmore 1105805800 KENMORE AUTOMATIC WASHERS
Kenmore 1105805801 KENMORE AUTOMATIC WASHER
Kenmore 1105805802 KENMORE AUTOMATIC WASHER
Kenmore 1105805803 KENMORE AUTOMATIC WASHER
Kenmore 1105805804 KENMORE AUTOMATIC WASHER
Kenmore 1105805850 KENMORE AUTOMATIC WASHERS
Kenmore 1105805851 KENMORE AUTOMATIC WASHER
Kenmore 1105805852 KENMORE AUTOMATIC WASHER
Kenmore 1105805853 KENMORE AUTOMATIC WASHER
Kenmore 1105805854 KENMORE AUTOMATIC WASHER
Kenmore 1105805950 KENMORE AUTOMATIC WASHER
Kenmore 1105805951 KENMORE AUTOMATIC WASHER
Kenmore 1105805952 KENMORE AUTOMATIC WASHER
Kenmore 1105805953 KENMORE AUTOMATIC WASHER
Kenmore 1105807100 KENMORE GAS DRYER
Kenmore 1105807300 KENMORE GAS DRYER
Kenmore 1105807410 KENMORE GAS DRYER
Kenmore 1105807500 KENMORE GAS DRYER
Kenmore 1105807501 KENMORE GAS DRYER
Kenmore 1105807700 KENMORE GAS DRYER
Kenmore 1105807701 KENMORE GAS DRYER
Kenmore 1105807800 KENMORE GAS DRYER
Kenmore 1105807801 GAS DRYER
Kenmore 1105807810 KENMORE GAS DRYER
Kenmore 1105807811 KENMORE GAS DRYER
Kenmore 1105807850 KENMORE GAS DRYER
Kenmore 1105807851 GAS DRYER
  #2 (permalink)
Old 12-18-2012, 03:36 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
The two plugs may be holding things up, try removing them first. If it still won't come loose, screw the spanner nut back on just a few threads but not tight against the tub. Have someone else lift upwards on the tub while you wack straight down on the nut with hammer.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Cabrio inner basket removal flagxj Washer Repair 1 09-02-2012 08:13 PM
basket removal jerryrhodes Washer Repair 1 07-26-2012 04:12 AM
Top Basket Removal JACK1965 Dishwasher Repair 0 03-31-2011 12:44 PM
inner basket removal dpuccetti Washer Repair 0 03-04-2009 07:00 PM
washer basket removal dragracer Washer Repair 0 01-10-2009 09:33 AM
