| » GE Washer flood hose leaks after filling |
Model Number: WBB2090G5WW Brand: GE Age: 5 - 10 years
it appears to only do this on Super load setting, I can live with 'Large' setting but am worried this might be the sign of a larger problem I should look into? Any easy ways to see what is causing the overflow(I'm assuming it's overflowing since it's coming out of the flood pipe at the bottom?)
Check the air dome and hose on the lower left side of the outer tub for gunk. Also make sure the hose connection is tight at the air dome as well as at the pressure switch behind the control panel. Check the hose for any cracks/splits along its length. If no problem is found, I would replace the pressure switch and hose. Other possiblities are that one or more of the tub dampening straps is/are broken allowing too much motion of the tub assembly during agitation. Worn out suspension rods can also contribute to that. You can feel for the straps by reaching under the lid over the top of the tub at the sides of the cabinet. Two on each side.
Eric Last edited by fairbank56 : 12-18-2012 at 01:52 PM. |
| Display Modes | |
| Water coming out of flood hose...Help | DOITMYSELF2012 | Washer Repair | 5 | 07-25-2012 10:07 AM |
| Maytag Washer leaks on side of drain hose | della | Washer Repair | 1 | 12-18-2011 06:27 AM |
| Washer leaks when filling | Queenbee23 | Washer Repair | 2 | 11-21-2011 05:44 PM |
| Water Leaking from Hose Flood | dianabela | Washer Repair | 1 | 09-09-2011 06:50 PM |
| What does Flood hose | hjp509 | Washer Repair | 0 | 07-27-2011 02:17 PM |
