Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   GE Washer flood hose leaks after filling (http://forum.appliancepartspros.com/washer-repair/511809-ge-washer-flood-hose-leaks-after-filling.html)
houseboy23 12-18-2012 12:28 PM
it appears to only do this on Super load setting, I can live with 'Large' setting but am worried this might be the sign of a larger problem I should look into? Any easy ways to see what is causing the overflow(I'm assuming it's overflowing since it's coming out of the flood pipe at the bottom?)
fairbank56 12-18-2012 01:39 PM
Check the air dome and hose on the lower left side of the outer tub for gunk. Also make sure the hose connection is tight at the air dome as well as at the pressure switch behind the control panel. Check the hose for any cracks/splits along its length. If no problem is found, I would replace the pressure switch and hose. Other possiblities are that one or more of the tub dampening straps is/are broken allowing too much motion of the tub assembly during agitation. Worn out suspension rods can also contribute to that. You can feel for the straps by reaching under the lid over the top of the tub at the sides of the cabinet. Two on each side.
Eric
