| » Will not agitate ? |
That's a 13 year old model. So it fills, stops filling and then does nothing? Could be the water level pressure switch or the timer. Lid switch is ok if it's spinning. You can check the pressure switch with a multimeter. Need to open control panel to get to the pressure switch and open the front panel to get to the pressure hose. Remove hose from air dome on left side of tub and gently blow into it to activate the switch while checking continuity across switch terminals where the yel/blk and vio wires connect. Unplug washer of course for this test.
Eric Last edited by fairbank56 : 12-17-2012 at 06:24 PM. |
| Display Modes | |
| Won't agitate | bandonmike | Washer Repair | 4 | 02-06-2012 11:29 AM |
| Agitate | kimhonaker | Dishwasher Repair | 0 | 09-27-2010 06:18 AM |
| will not agitate | luzeeta | Washer Repair | 0 | 03-17-2010 07:06 AM |
| Everything but Agitate | prov47 | Washer Repair | 2 | 06-18-2009 07:23 PM |
| GE won't agitate | Marc71 | Washer Repair | 2 | 04-29-2008 03:54 PM |
