| » Maytag washer not washing |
Model Number: MVWC6ESWW Brand: Maytag Age: 1 - 5 years
I have the Maytag washer MVWC6ESWW that is not agitating. Washer fills with water then stops. I can then hear the motor just hum and not agitate. I checked cap and it is good. The motor will however run to pump out the water. When the washer is in the motor hum state I can push the timer knob in just a little and the motor will start and the washer will agitate. The timer was replaced about 2 months ago. When the motor does run it smells hot. Any ideas? Motor? Timer again? Something else?Thanks
Hi.
It does sounds like the bad timer. Check also the motor plugs for bad connection. The timer Part number: W10243947 Here are the breakdown diagrams and 02-Controls and Rear Panel Parts parts for Maytag MVWC6ESWW1 - AppliancePartsPros.com Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Could be lid switch is bad. Move it to a different wash setting on the dial, if it still won't run the full cycle, $30 lid switch is a more likely cause.
Especially if you can use a pencil or small screwdriver to push the switch you should hear it click. |
If the washer is draining it's not the lid switch.
Simon.
__________________
| Display Modes | |
| Maytag washer not washing or spinning | ttdarkie | Washer Repair | 4 | 05-10-2010 07:59 PM |
| Maytag washer not washing or spinning | ttdarkie | Oven Repair (including Ranges and Cooktops) | 0 | 04-16-2010 02:58 PM |
| Maytag neptuen washer changes spin cylcle while washing. | DBoelman | Washer Repair | 1 | 11-17-2009 12:09 PM |
| Maytag washing machine | sally rushing | Washer Repair | 1 | 05-27-2009 09:14 AM |
