Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Hotpoint/GE plastic drum coupler (http://forum.appliancepartspros.com/washer-repair/511636-hotpoint-ge-plastic-drum-coupler.html)
Nitro itch 12-17-2012 05:48 AM
Plastic agitator to tub coupler won't ome off after removing the very rusty agitator center bolt? Any tricks to get it off? Or should I cut it off with Dremel Tool.
fairbank56 12-17-2012 10:00 AM
Brute force should get it off. You would have to do an awlful lot of cutting with a dremel to get down to the splined hub. It's attached to the splined agitator shaft, not the tub.
Eric
