| » tricky (for me ) problem! |
Model Number: 110.2110212 Brand: Kenmore Age: Less than 1 year
Hi I have a tricky one(for me) I would really appreciate your expertise with. Kenmore top load automatic, mod. 110.21102012. Fairly new. still with warranty, but warranty is no good if debris is caught in it? Anyway it fills and agitates fine. lid is locked during agitation, you must pause it to unlock. after wash cycle the timer does not advance, it won't drain or spin (it will drain manually). there is nothing in the pump chamber and hoses are not blocked. If i manually set it to drain/spin it does nothing.there is no filter in the inner tub and i can't find a filter in the pump housing. So,do you have any suggestions? Thanks folks!, Jerry in upstate new york.
Hi.
Check if the drain pump gets 120VAC. If it does - replace it Part number: W10276397 If not - check the connections at the control board and if needed - replace it W10445385. Locate the tech sheet inside the cabinet and run diagnostic test - "wont drain" Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 12-14-2012 at 06:09 PM. |
| Display Modes | |
| Tricky evaporator fan | Geno H | Refrigerator & Freezer Repair | 3 | 05-18-2011 03:10 PM |
| tricky helix cap | Mac Bleakley | Refrigerator & Freezer Repair | 0 | 02-03-2010 08:28 AM |
| tricky warm water selection | ckerdflag | Washer Repair | 2 | 01-05-2009 07:57 AM |
| Washer problem in LARGE load setting- timer problem? | jagtianis | Washer Repair | 9 | 08-04-2008 02:49 AM |
