The washer agitates fine, but when it comes to the rinse and spin cycle, it doesn't always spin. If it doesn't spin, it will be making noises like it is trying to spin. Sometimes if I lift the lid and close again, it may or may not spin. What could be causing this?
Groups: Expert
The clutch is likely slipping. See video on how to replace. Eric
Thanks. Do I likely need the "clutch assembly" or the "clutch band & lining kit"?
Groups: Expert
Depends on the condition of your clutch hub. $12 difference in price.
Eric
Originally Posted by: fairbank56 Depends on the condition of your clutch hub. $12 difference in price.
Eric Ok. Thanks
