Discuss
Trouble with a Gear Case Seal Cover 3349985
 in
Washer Repair
Hi, I need to replace the gear case seal of my old Whirlpool direct drive washer. I ordered a new
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Trouble with a Gear Case Seal Cover 3349985
  #1 (permalink)
Old 12-13-2012, 03:38 PM
Junior Member
veda1 is on a distinguished road
Default Trouble with a Gear Case Seal Cover 3349985
Brand: Whirlpool   Age: More than 10 years
Hi, I need to replace the gear case seal of my old Whirlpool direct drive washer. I ordered a new one but I am having trouble installing it. The questioning comes from the fact that I am not the one who dissembled it. I am not even sure which side it goes. I settled with the flat side going on top of the gear case. The problem is that I can't push it all the way in the hole. I put oil around, heated it up but it won't go all the way the top edge of the case hole. Am I doing something wrong? Or is it the way it is supposed to be? I just doesn't want to mess up. I include some pictures... Thanks
part: Gear Case Seal Cover 3349985
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower Shaft Seal on Gear Box Hotpoint Belt Driven wyocwboy Washer Repair 4 07-12-2012 05:18 PM
Lower Seal Leaking Oil on Transmission or Gear Box wyocwboy Washer Repair 0 07-05-2012 11:31 AM
Whirlpool Thin Twin with slow leak (bad gear case?) agegg23 Washer Repair 1 09-28-2010 08:44 AM
Whirlpool washer gear case pjgodchaser Washer Repair 2 03-07-2009 10:38 PM
whirlpool gear case clutch bryankw Washer Repair 1 04-11-2008 10:32 AM
