Discuss
GE top load washer will not agitate it will spin.
 in
Washer Repair
WJSR2020B2WWmodel # Ads By Google
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE top load washer will not agitate it will spin.
  #1 (permalink)
Old 12-13-2012, 11:15 AM
Junior Member
tacohead59 is on a distinguished road
Default GE top load washer will not agitate it will spin.
Brand: GE   Age: 5 - 10 years
WJSR2020B2WWmodel #
Ads By Google
  #2 (permalink)
Old 12-13-2012, 01:39 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Assume that's a 2070 model (not 2020). If the motor does not run during agitate mode it could be a pressure switch or timer issue. After it fills and stops, flip the load size switch back and forth, tap on it, if it doesn't kick on, unplug washer, remove the control panel and disconnect the wiring from the pressure switch. Make a jumper and short the violet and yellow/black wires together. Make sure the terminals aren't touching anything (tape if necessary). Plug washer back in. If it starts agitating, replace the pressure switch. If not, the timer is likely defective.
Eric
  #3 (permalink)
Old 12-13-2012, 04:13 PM
Junior Member
Default
The motor runs during agitation
  #4 (permalink)
Old 12-13-2012, 04:19 PM
Expert
APP Volunteer
Default
Oh, well...ok, can you grab the fins on the lower agitator and rotate it by hand? If so, the splines inside the agitator coupler are likely stripped out.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My GE top load washer does not agitate or spin. jenjenrosebud Washer Repair 7 03-26-2013 07:06 PM
Top load washer won't spin or agitate wainbern Washer Repair 1 10-13-2010 04:50 PM
front load washer no agitate or spin plmtrxpjp Washer Repair 1 03-05-2010 11:11 AM
front load washer will not agitate or spin shadpch Washer Repair 1 11-08-2008 04:08 PM
Kenmore top-load washer does not spin or agitate HarryD Washer Repair 6 09-19-2008 02:57 PM
