Discuss
Burning Plastic Smell After Replacing Drive Coupling
 in
Washer Repair
The washer started making a loud ratcheting noise during agitation and spin. We suspected the drive coupling and, sure enough,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Burning Plastic Smell After Replacing Drive Coupling
  #1 (permalink)
Old 12-12-2012, 08:16 PM
Junior Member
bcrayle is on a distinguished road
Question Burning Plastic Smell After Replacing Drive Coupling
Model Number: 110.92491210   Brand: Kenmore   Age: More than 10 years
The washer started making a loud ratcheting noise during agitation and spin. We suspected the drive coupling and, sure enough, it had cracked and split. So we got a replacement from a Sears parts store and put it in. Note that the replacement doesn't look exactly like the original - the pins and holes are a different shape - but it appeared to fit OK and it DOES look like the replacement part shown for this model on several websites. We also replaced the fill valve while we had the washer apart, since it had gotten to where it filled very slowly. The washer seems to work - fills like it did when it was new, agitates, drains, spins. But during the spin cycle we noticed an increasing "hot plastic" smell that changed over to a sharp "burning plastic" smell...so we killed power and took it back apart. Nothing is obviously damaged or more worn than before. Any idea what we likely did wrong?
Ads By Google
Related Models
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
  #2 (permalink)
Old 12-13-2012, 06:58 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Take a second look at the connections (motor switch, lid switch) to make sure they're tight, and there is no electrical arcing. Also, run the machine in spin for a couple of minutes, then spray a mist of water on to the clutch housing. If it (sizzles) or hisses, chances are high that you'll need to replace the clutch. This is a medium difficulty job; but there are excellent video tutorials available on this site for this.
  #3 (permalink)
Old 12-14-2012, 02:25 PM
Junior Member
Smile Thank you!
Thank you so much for your response! We looked things over, put it back together, and ran it. The smell hasn't returned. I don't know whether it was electrical, as you suggested (there was nothing obvious, but it could have been - nothing else was obvious either) or whether we just didn't have the coupler seated quite right or something.
In any case, we're quite happy. This has been a good washer - 17 years and still going strong - and we're happy it's working again.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer - burning plastic smell camdryerman Dryer Repair 0 08-24-2012 12:51 PM
Kenmore Freezer burning plastic smell Fourniro Refrigerator & Freezer Repair 0 04-29-2012 03:47 PM
Burning plastic smell from gas range consumer Mel Oven Repair (including Ranges and Cooktops) 2 02-28-2011 11:36 AM
Plastic Burning Smell brianmcc2005 Refrigerator & Freezer Repair 1 10-14-2010 02:44 AM
burning smell after replacing motor coupling sturg3636 Washer Repair 2 04-12-2010 05:28 PM
