| » Maytag Washer Finishing Spin Cycle Without Draining |
Model Number: MAV7700AWW Brand: Maytag Age: 5 - 10 years
[FONT='Verdana','sans-serif']I have an issue on my machine where the machine goes into the spin cycle without draining first and will usually spin the water out the top of the tub if it is a large load and I dont catch it fast enough.
I changed the timer which solved the problem for a while. The problem came back so I replaced the timer again thinking the 1st replacement was faulty. Again is solved the issue for some time but it came back again. I called an appliance repair guy who suggested changing out the lid switch and water level switch. Again it seemed to solve the issue for a little only to have the problem return. During the spin cycle I either need to pull out the knob or lift the lid to stop the machine. Once I start it again it drains without an issue. The issue seems to happen in any cycle (color, whites & delicate) and the load size doesn't seem to matter either (except that if I do a super load it will overflow during the spin cycle). When the problem went away it usually came back after we didn't use the machine for a week or longer. Looking to get some advice on what my next steps to fix the machine should be. Thanks.[/font] Ads By Google Related Models |
Hello,
Tilt the washer back. Remove the belt and check it. Check how freely the pump pulley is rotating in both directions. Here are the breakdown diagrams and Parts for Maytag MAV7700AWW Washer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Kenmore washer that stops and starts repeatedly before finishing the cycle | johnboysc | Washer Repair | 0 | 03-02-2012 10:37 AM |
| Washer not Draining or spin cycle | kevbayer | Washer Repair | 5 | 11-15-2011 12:33 PM |
| GE High-Effciency Washer not finishing spin cycle | nikkisdolphin | Washer Repair | 1 | 04-13-2011 08:10 AM |
| washer not finishing or draining | grimmjowe | Washer Repair | 5 | 06-03-2010 11:42 PM |
| Cycle not finishing | rjf | Dishwasher Repair | 0 | 06-16-2008 08:47 AM |
