| » Washer makes loud noise like grinding |
Model Number: Wtw4800xq1 Brand: Whirlpool Age: Less than 1 year
Ive got a whirlpool wte4800xq1 that makes a loud gear stripping like noise. Upon researching I have found several people and a technition who recommended I check the pulley nut to see if loose...i would like to know where this is located how to get to it and what it looks like if possible. My daughter had triplets recently and well...needless to say er really need to fix this. Thank you so much
Hi.
You should check: - the drive pulley and nut ( loose, cracked or worn out) - belt (cracks and missed pieces) - drain pump - transmission All this parts you can check from underneath the washer. Here are the breakdown diagrams and Gearcase, Motor and Pump parts for Whirlpool WTW4800XQ1 - AppliancePartsPros.com Post thew results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You have to lay the machine on it's front side to get to the bottom where these parts are. Remove the belt shield to get to the nut on the pulley. If it is loose, apply some blue 242 loctite before tightening. Another common problem with this unit is the shifter. It shifts the splutch between agitate and spin mode. It is the device next to the large pulley that has "synchronous motor" written on it. You didn't say when it makes this noise.
Eric |
| Display Modes | |
| Dishwasher makes loud grinding type noise, and wash are doesn't turn | kshah2k10 | Dishwasher Repair | 0 | 07-31-2010 09:33 AM |
| washer wont spin makes loud grinding noise | mammasuze | Washer Repair | 1 | 07-11-2010 04:06 PM |
| ge washer makes loud grinding noise while washing | ruthmccoy | Washer Repair | 0 | 04-25-2010 08:44 AM |
| Washer makes grinding noise while washing | RitchMc | Washer Repair | 1 | 11-10-2009 01:11 PM |
| Washer makes grinding noise. | Joseph01 | Washer Repair | 1 | 09-02-2009 05:50 AM |
