| » Loud noise and vibration end of spin cycle |
Model Number: Ultimate care II Brand: Whirlpool Age: 5 - 10 years
Hi, our washing machine works fine at all the cycles except at the end of the spinning cycle. when it's time to stop, it makes a big loud noise like a concrete hammer with vibration as well and takes many seconds to stop. I had a look at the clutch but didn't see anything broken. The sound is as if it would be unbalanced but it's not and the drum inside seems to move wich might be creating the bang.
i just want to make sure it is the right piece I change before ordering it. I don't want to spend money for no reason. Thanks for your help. Ads By Google Related Models |
Sounds like a drive block issue or possibly the brakes. Remove the agitator to inspect the drive block. It should look like the photo. Try turning the basket by hand which you normally should not be able to do without a lot of force. If it turns easily and the drive block is ok then the brakes are bad. The drive block and tabs on the drive tube should turn in unison. If the drive block is shot, you will need a spanner wrench to get the nut off. If the tabs on the drive tube are shot, you will need to replace the basket drive assembly.
Eric ![]() Last edited by fairbank56 : 12-11-2012 at 09:00 AM. |
| Display Modes | |
| Loud noise during spin cycle | Roadrider18 | Washer Repair | 3 | 10-05-2012 05:23 AM |
| microwave heats, has loud noise with vibration | thenurseana | Microwave Repair | 0 | 08-21-2012 08:20 PM |
| loud noise/vibration during wash cycle | briandodd | Dishwasher Repair | 0 | 02-05-2011 09:46 AM |
| loud noise on spin cycle,the faster the spin gets the louder the winnig gets | Edward Loeb | Washer Repair | 3 | 02-02-2011 07:30 AM |
| Loud noise during spin cycle | tbirdlover | Washer Repair | 8 | 01-19-2011 12:22 PM |
