Discuss
water leak after replacing the clutch
 in
Washer Repair
The clutch was replaced and the repairman said that it was fixed. After this water leaks under the washer. The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water leak after replacing the clutch
  #1 (permalink)
Old 12-10-2012, 06:29 AM
Junior Member
mc3b is on a distinguished road
Default water leak after replacing the clutch
Brand: Roper   Age: 1 - 5 years
The clutch was replaced and the repairman said that it was fixed. After this water leaks under the washer. The serviceman said that it wasn't due to the repair. This was not a problem prior to his work. What coukd be the problem? Is the serviceman right or not?
Ads By Google
  #2 (permalink)
Old 12-10-2012, 07:07 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
We need the model number. The servicman should look at the washer to determine if he may have caused the new problem.
Eric
  #3 (permalink)
Old 12-10-2012, 10:18 AM
Junior Member
Default
Quote:
Eric
Model# is SM5425493-A
  #4 (permalink)
Old 12-10-2012, 10:20 AM
Junior Member
Default
Model # SM5425493-A
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing clutch seagull5 Washer Repair 6 04-08-2012 08:17 AM
GE Washer clutch needs replacing? Tami Ragusa Washer Repair 1 09-02-2011 05:04 PM
FAV6800AWW Clutch Issue - Signs of Water Leak 4MMsDad Washer Repair 3 04-18-2011 11:53 AM
Replacing Clutch in Maytag Top loader greeneye Washer Repair 1 09-01-2010 10:02 AM
help replacing clutch rednran Washer Repair 5 02-14-2008 06:27 AM
