Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   water leak after replacing the clutch (http://forum.appliancepartspros.com/washer-repair/510199-water-leak-after-replacing-clutch.html)
mc3b 12-10-2012 06:29 AM
The clutch was replaced and the repairman said that it was fixed. After this water leaks under the washer. The serviceman said that it wasn't due to the repair. This was not a problem prior to his work. What coukd be the problem? Is the serviceman right or not?
fairbank56 12-10-2012 07:07 AM
We need the model number. The servicman should look at the washer to determine if he may have caused the new problem.
Eric
mc3b 12-10-2012 10:18 AM
Quote:
Eric
Model# is SM5425493-A
mc3b 12-10-2012 10:20 AM
Model # SM5425493-A
