| » Kenmore 90 won't agitate but will spin |
Model Number: 11026932690 Brand: Kenmore Age: More than 10 years
If I put in a reg load the washer dulls up but will not agitate. Then go's to drain then spins ok. I thought it was the motor but that works well. It was working for a while ok on small loads but not it won't agitate on any cycle. Any ideas. The washer is a great shape it had regular maintanance but the policy ran out and I think I can fix this with your tech help. Thanks
Hi.
You need to determine if this is bad agitator or transmission. Remove the agitator and see if the transmission shaft is turning back and forth and you can't stop it by hand. If that the case - replace the agitator Part number: 3947517 If you can stop the shaft or it's not moving at all - replace the transmission Part number: 3360629 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
It wood be very helpful if you share with us all the info about the problem in the beginning. Based on the info you provided it's a bad timer Part number: 3951770 Simon.
__________________
| Display Modes | |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
| Kenmore does not agitate, spin and drain | Help_Please | Washer Repair | 3 | 10-24-2010 02:31 AM |
| Kenmore no spin OR spin & agitate simultaneously | Badtiming | Washer Repair | 0 | 10-12-2010 11:01 PM |
| Kenmore won't agitate or spin Help! | jeffraab | Washer Repair | 2 | 11-06-2009 05:28 PM |
| Kenmore won't agitate or spin | Steve Stallings | Washer Repair | 7 | 06-10-2009 11:54 AM |
