| » kenmore washer gets to driain or spin then stops |
Model Number: 110.22952100 Brand: Kenmore Age: 5 - 10 years
washer gets to spin and drain cycle and stops . sometimes with water sometimes doesn't drain good. Wife puts it in different cycle mode and it will work. timer?
If it will work correctly in a different cycle then this implies there is no mechanical problem and that you are correct in that the timer is the issue.
Try changing it out, if you buy from this site and the timer does not fix the problem you can return it.
__________________
| Display Modes | |
| Kenmore/Whirlpool Washer stops at drain before spin | christopher2012 | Washer Repair | 1 | 12-29-2011 10:20 AM |
| Kenmore washer stops too quick after spin | f_barton | Washer Repair | 1 | 12-21-2011 06:55 PM |
| washer stops at spin cycle | dyemg | Washer Repair | 0 | 12-04-2011 11:20 AM |
| Kenmore washer won't drain, starts spin cycle stops trips circuit breaker | m789h | Washer Repair | 6 | 01-14-2011 06:38 PM |
| Kenmore 70 series stops before final spin cycle | jakeclifford | Washer Repair | 1 | 10-11-2009 11:42 AM |
