| » Washer will not drain or spin |
Model Number: GLWS1233AS1 Brand: Frigidaire Age: 5 - 10 years
Washer will agitate but will not drain or spin.
Drain pump - Pulled pump, the lines were clear so was pump however the fins/shaft had a lot of play...replaced with new pump...same problem. Switch - still has the "click"... Belt - Have read that this could be a potential problem source however the washer agitates fine, belt appears in good condition and rotates manually. Suggestions?? Ads By Google Related Models |
| Display Modes | |
| LG washer will not drain or spin | rangers02 | Washer Repair | 1 | 11-13-2011 06:30 PM |
| washer won't drain or spin | sissy25 | Washer Repair | 1 | 01-10-2011 07:48 AM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
