Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Washer will not drain or spin (http://forum.appliancepartspros.com/washer-repair/509867-washer-will-not-drain-spin.html)
NC Native 12-08-2012 06:56 AM
Washer will agitate but will not drain or spin.
Drain pump - Pulled pump, the lines were clear so was pump however the fins/shaft had a lot of play...replaced with new pump...same problem.
Switch - still has the "click"...
Belt - Have read that this could be a potential problem source however the washer agitates fine, belt appears in good condition and rotates manually.
Suggestions??
