| » ge front loader not turning |
Model Number: GcvH6260 FWW Brand: GE Age: 5 - 10 years
Hope you can help me . I have been reading alot on your site for testing front loading washers
This is what i have done so far, I put the washer in test mode and checked for error readings but none came up but a old one for the pump that i replaced . ok i did the inverter test . as soon as i put the washer in test mode i had 120 vac to the blue and red wires ? had power all the time i was using the test mode is this good or bad . then i checked the motor for 6 ohms blue to white blue to red white to red , all had reading of 6ohms . next i checked the sensor resistance value and it was 116.5 ohms not 118 ohms , is that the problem , not sure now . note this washer is a canadian model . i dont know if that would change anything or not, hope you can help me in the right direction. glen Ads By Google Related Models Last edited by rykrishell : 12-07-2012 at 03:40 PM. Reason: update |
The model number you posted does not come up. Verify and repost it please.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
thanks for the reply Gene . this is a washer that is from canada . here is the imformation thats on the side of the washer .
Generral Electric company model GCVHh6260fww s/N sh201266t 120v 60 hz 12a Louisvilie ky washing machine 25rz p/no WMBa0000000050ww hope you can help |
If the 120 VAC is present at the inverter AC input harness and motor resistance is correct, replace the inverter.
I'm not able to find the correct part number for the inverter because we do not have access for non American models parts list. Gene.
__________________
Quote:
thanks Gene i will replace the inverter and will post back , thanks again for your help |
Quote:
Quote:
Very likely this is the correct part number but I'm not able to verify it. Gene.
__________________
Quote:
__________________
Quote:
Well Gene i put in the new inverter and the washer is up and running great . I was using it all weekend with no trouble at all . I really like to thank you for all the help that you gave .I had know idea what to do before i found this form and started reading and asking questions .Merry Christmas to all |
You are welcome. I'm glad it's up and running.
Merry Christmas to you and your loved ones! Gene.
__________________
| Display Modes | |
| GE Front end loader | debbmitchell | Washer Repair | 1 | 01-09-2012 05:20 PM |
| How to remove the front cabinet panel form BOsch front loader wfmc3200 washer | rharrige | Washer Repair | 1 | 05-05-2011 03:01 PM |
| kenmore front loader fell onto front while moving. | ohhhden | Washer Repair | 1 | 01-26-2010 07:22 PM |
| LG front loader | ksharp | Washer Repair | 1 | 05-14-2009 05:34 PM |
| ge front loader | rmitzel | Washer Repair | 0 | 10-11-2008 08:11 PM |
