Discuss
kenmore washer 70 series
 in
Washer Repair
i have a washer that will not spin or agitate. replaced the coupler on it and it worked for a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer 70 series
  #1 (permalink)
Old 12-06-2012, 11:58 AM
Junior Member
kristief is on a distinguished road
Unhappy kenmore washer 70 series
Brand: Kenmore   Age: 1 - 5 years
i have a washer that will not spin or agitate. replaced the coupler on it and it worked for a little bit but went back to not working again it will not spin or agitate. does anyone know what the hell they are doing with washers...this is so stressful with no damn washer
Ads By Google
  #2 (permalink)
Old 12-08-2012, 06:46 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The first thing I would do is check to make sure the new coupling is on right and is not a problem.
I understand your stress from these repairs, and if it is too great then I think you should consider having a service tech make the repair for you.
__________________
  #3 (permalink)
Old 12-17-2012, 12:13 AM
Junior Member
Dooz2_48 is on a distinguished road
Default Causes
Quote:
Ok, . . . if the machine was "klack"-ing, then the coupler needed to be replaced, but the first thing I check for is the lid switch gone bad. I bypass the lid switch with a piece of insulated 14 ga wire (a small piece of Romex does fine, strip the ends of the insulation about 1/2", and place one end of the wire into the side of the Molex connector that has the black wire coming from the timer, and the other end of your bypass in the side of the Molex connector with the white wire). Then, turn the dial on the timer to see if it will fill and advance through the cycles. If so, then the lid switch needs to be replaced. If the timer doesn't advance by itself, . . . then the timer needs to be replaced. Only when the coupler is making a real racket, like "klack"ing does the coupler need to be replaced.
Let me know how it goes. ok?
Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Kenmore 70 series JimboHo Washer Repair 3 11-23-2011 06:24 PM
Kenmore 90 plus series washer eclay Washer Repair 5 10-02-2010 01:26 PM
Kenmore 90 Series Washer Clifford Lasseigne Washer Repair 2 06-15-2009 05:50 AM
Kenmore 70 series washer Jody G Washer Repair 1 01-05-2009 04:22 PM
Kenmore 90 Plus Series Washer jeremyh65 Washer Repair 5 02-27-2008 11:35 AM
