Discuss
Whirlpool - how do I know what to replace?
 in
Washer Repair
Hi. You are most welcome. I believe, you should be able to find the bolt in a machine shop/hardware store.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool - how do I know what to replace?
  #11 (permalink)
Old 12-13-2012, 03:56 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
And I don't recall replacing this bolts.
Good luck.
Simon.
Ads By Google
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #12 (permalink)
Old 12-15-2012, 03:55 PM
Junior Member
cptmoney is on a distinguished road
Default
Simon -
One quick question:
I installed the new clutch, and it's rockin'. I still have one quick question, however...
At the very last rinse cycle, the machine just pumped, but didn't spin. Once it was completely drained, it did spin. BUT - I had the controls set to "extra spin" just to be sure that things were spinning...which they did for the entire cycle.
I was sort of under the impression that it was to be spinning every single time that it was pumping - but I may be wrong on that.
What do you think about that?
  #13 (permalink)
Old 12-17-2012, 10:17 AM
Expert
Default
That's depend on the internal timer set up.
Simon.
__________________
  #14 (permalink)
Old 12-18-2012, 06:18 AM
Junior Member
Default
Quote:
Simon.
How do I determine this?
I'll do one more additional test to see if it spins during the final "drain" cycle, but I believe that we're ready to go on this project. Everything else seemed to be functioning at 100%.
Prior to the clutch replacement, it wasn't spinning at all, EVER, so I know we've made some significant progress on it.
  #15 (permalink)
Old 12-18-2012, 06:35 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
The washer has a neutral drain gearcase. When it first starts draining directly after agitation, it should drain for a minute or two without spinning. The motor should then pause for a few seconds and when it starts again, it should be draining and spinning to the end of cycle. The pausing of the motor causes the release of the neutral drain mechanism to allow spinning when it starts again.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace Whirlpool Ice Door cblake1811@gmail.com Refrigerator & Freezer Repair 1 07-29-2010 05:48 PM
Replace Ignitor for Whirlpool Range qosmic Oven Repair (including Ranges and Cooktops) 0 05-19-2010 08:13 PM
Help to replace a WHIRLPOOL Microwave Handle drraj Microwave Repair 0 09-04-2009 12:05 PM
replace basket on whirlpool jkm Washer Repair 3 02-17-2009 05:53 PM
Replace Whirlpool compressor John C Refrigerator & Freezer Repair 5 03-12-2008 07:30 AM
