| » Samsung WF330AN front load washer is continuously filling with water from a valve in |
Model Number: wf330an* Brand: Samsung Age: 1 - 5 years
The machine seems to be washing just fine, and going through all of the appropriate cycles, but I can see the water running down the inside of the door, from a small valve at the top of the door seal, on the inside of the door. I have checked the external hose connections for kinks or leaks, cleared the filter, and made sure the hose is clear of clogs, but it is still leaking. Is this something I could fix myself, or is it something I need to have serviced?
Hi.
Remove the top cover by taken screws out from the back and sliding the top back and up. Locate the water valves near the dispenser. There are cold and hot water valves.Check which one is bypassing the water and replace it. Please get a complete model number of the washer. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| How to replace door diaphragm on a Samsung front load washer | Geroge | Washer Repair | 0 | 04-22-2012 07:35 PM |
| Samsung front load washer not cleaning properly | kcarz3 | Washer Repair | 0 | 11-14-2011 07:19 PM |
| No Drain on Samsung front load washer | flashpix | Washer Repair | 1 | 10-14-2011 01:55 AM |
| Kenmore front load washer beeps continuously | jwes | Washer Repair | 0 | 11-30-2010 04:35 PM |
| Samsung Front load washer | Bootmaker | Washer Repair | 2 | 04-15-2010 06:27 AM |
