Discuss
Whirpool Duet
 in
Washer Repair
Hello. I have a WFW9640 Duet Steam I bought from Lowe's. The washer washes fine but when it comes time
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirpool Duet
  #1 (permalink)
Old 12-06-2012, 07:15 AM
Junior Member
spencer5 is on a distinguished road
Default Whirpool Duet
Model Number: WFW9640   Brand: Whirlpool   Age: 1 - 5 years
Hello. I have a WFW9640 Duet Steam I bought from Lowe's. The washer washes fine but when it comes time to spin it spins up but cant seem to find a balance and does not kick into high speed. Must be some kind of "tilt" mechanism. It will stop and try to re balance only to start the process over and do it again. I checked the bearing and belt gear in the back they seem fine. The shocks and springs are in tact and it drains fine. I also tried with the machine empty and with one towel both times worked fine. I ran a load of 7 towels and applied pressure to the front and back of the outer tub with my hands as it started spinning to help it balance it and it worked. Also. might mention the tub seems to be angling down from the front to the back. Not sure what the exact fall but its noticeable. Do the springs or shocks ever need replacing? If not, any ideas? The machine is only 13 months old. Thanks in advance for any help.
Steve
Ads By Google
Related Models
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
Whirlpool WGE33001 30" Electric Range E - Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E - Z Clean Oven
Whirlpool WGE34304 30" Electric Range E - Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
White Westinghouse WGF317ESB White Westinghouse/range
White Westinghouse WGF317ESC White Westinghouse/range
Frigidaire WGF321WADA Wwh(v1) / Gas Range
Frigidaire WGF321WADB Wwh(v1) / Gas Range
Frigidaire WGF321WAWA Wwh(v2) / Gas Range
Frigidaire WGF321WAWB Wwh(v2) / Gas Range
Frigidaire WGF323BADA Wwh(v3) / Gas Range
Frigidaire WGF323BADB Wwh(v1) / Gas Range
Frigidaire WGF323BADC Wwh(v1) / Gas Range
Frigidaire WGF323BADD Wwh(v1) / Gas Range
Frigidaire WGF323BADE Wwh(v1) / Gas Range
Frigidaire WGF323BAWA Wwh(v4) / Gas Range
Frigidaire WGF323BAWB Wwh(v2) / Gas Range
Frigidaire WGF323BAWC Wwh(v2) / Gas Range
Frigidaire WGF323BAWD Wwh(v2) / Gas Range
Frigidaire WGF323BAWE Wwh(v2) / Gas Range
Frigidaire WGF324BBDB Wwh(v0) / Gas Range
Frigidaire WGF324BBDC Wwh(v1) / Gas Range
Frigidaire WGF324BBWB Wwh(v0) / Gas Range
Frigidaire WGF324BBWC Wwh(v2) / Gas Range
Frigidaire WGF325BADA Wwh(v5) / Gas Range
Frigidaire WGF325BADB Wwh(v1) / Gas Range
Frigidaire WGF325BADC Wwh(v1) / Gas Range
Frigidaire WGF325BADD Wwh(v1) / Gas Range
Frigidaire WGF325BAWA Wwh(v6) / Gas Range
Frigidaire WGF325BAWB Wwh(v2) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Duet Sport Deasley1 Washer Repair 2 05-30-2010 10:21 AM
whirpool duet victorarbuet Washer Repair 2 12-10-2008 08:13 PM
whirpool duet washer deadhead Washer Repair 1 07-12-2008 12:57 PM
whirpool duet washer deadhead Dishwasher Repair 0 07-12-2008 12:45 PM
Whirpool Duet Washer mansoor ali Washer Repair 1 12-16-2007 07:45 PM
