Discuss
Maytag Neptune Washer shuts off
 in
Washer Repair
Our Maytag Neptune stackable washer fills, then shuts off after a minute or so. When we advance the timer manually,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune Washer shuts off
  #1 (permalink)
Old 12-05-2012, 09:23 PM
HHB HHB is offline
Junior Member
HHB is on a distinguished road
Default Maytag Neptune Washer shuts off
Model Number: MLE2000AYW   Brand: Maytag   Age: 5 - 10 years
Our Maytag Neptune stackable washer fills, then shuts off after a minute or so. When we advance the timer manually, it will drain, and then shut off again. It never agitates or spins. After some research, we removed the machine control board and inspected, but no signs of burned traces. For good measure, we installed a new wax motor even though the old one seemed to actuate OK and the door lock light was on when it seemed like it should be, but it didn't change anything. We ran the motor control board test per the manual by disconnecting the JP4 connector and applying AC to the correct inputs on the board, and the washer spun at 50 RPM as stated, so I assume we can say that the motor control board is fine?
Any other suggestions on what to check from here would be appreciated. The machine fills fine (it's not slow), and all fill temp settings seem to work fine. There are a lot of posts of this nature, but I couldn't find any that matched these specific symptoms. Thanks for any assistance.
Ads By Google
Related Models
Maytag MLE2000AYW Stacked Laundry - Ele
Maytag MLE2000AZW Stacked Laundry - Ele
Maytag MLE23MNAUW Dryer - Ele
Maytag MLE23MNAYW Stacked Dryer - Electric
Maytag MLE23MNFYW Stacked Dryer - Electric
International MLE23PDAGW Dryer - Ele
Maytag MLE23PDAUW Dryer - Ele
Maytag MLE23PDAYQ Stacked Dryer - Electric
Maytag MLE23PDAYW Stacked Dryer - Electric
Maytag MLE23PDFGW Stacked Dryer - Electric
Maytag MLE23PDFUW Stacked Dryer - Electric
Maytag MLE23PDFYW Stacked Dryer - Electric
Maytag MLE23PDFZW Stacked Dryer - Electric
Maytag MLE23PDHGW Stacked Dryer - Electric
Maytag MLE23PDHYW Stacked Dryer - Electric
Maytag MLE23PDHZW Stacked Dryer - Electric
Maytag MLE23PRAYW Stacked Dryer - Electric
Maytag MLE23PRFYW Stacked Dryer - Electric
Maytag MLE23PRFZW Stacked Dryer - Electric
Frigidaire MLF303PGDA Frg(v1) / Gas Range
Frigidaire MLF303PGDC Frg(v1) / Gas Range
Frigidaire MLF303PGDD Frg(v2) / Gas Range
Frigidaire MLF303PGWA Frg(v2) / Gas Range
Frigidaire MLF303PGWC Frg(v3) / Gas Range
Frigidaire MLF303PGWD Frg(v4) / Gas Range
Frigidaire MLF311SGDA Frg(v1) / Gas Range
Frigidaire MLF311SGDC Frg(v1) / Gas Range
Frigidaire MLF311SGDD Frg(v1) / Gas Range
Frigidaire MLF311SGWA Frg(v2) / Gas Range
Frigidaire MLF311SGWC Frg(v2) / Gas Range
Frigidaire MLF311SGWD Frg(v2) / Gas Range
International MLG15MNAEW Dryer - Gas
Maytag MLG15MNAGW Dryer - Gas
Maytag MLG15MNAWW Stacked Dryer - Gas
International MLG15PDAEW Dryer - Gas
Maytag MLG15PDAGW Dryer - Gas
Maytag MLG15PDAWA Dryer - Gas
Maytag MLG15PDAWQ Dryer - Gas
Maytag MLG15PDAWW Dryer - Gas
Maytag MLG15PDAXA Dryer - Gas
Maytag MLG15PDAXQ Dryer - Gas
Maytag MLG15PDAXW Dryer - Gas
Maytag MLG15PDBGW Dryer - Gas
Maytag MLG15PDCXA Dryer - Gas
Maytag MLG15PDCXQ Dryer - Gas
Maytag MLG15PDCXW Dryer - Gas
Maytag MLG15PRAWW Stacked Dryer - Gas
Maytag MLG15PRAXW Stacked Dryer - Gas
Maytag MLG19PDAEW Stacked Laundry - Gas
Maytag MLG19PDAGW Stacked Laundry - Gas
Maytag MLG19PDAWW Stacked Laundry - Gas
Maytag MLG19PDAXW Stacked Laundry - Gas
Maytag MLG19PDBGW Dryer - Gas
Maytag MLG19PDCXQ Dryer - Gas
Maytag MLG19PDCXW Dryer - Gas
Maytag MLG19PDDGW Stacked Laundry - Gas
Maytag MLG19PDDWW Stacked Laundry - Gas
Maytag MLG19PDSAW Stacked Laundry - Gas
Maytag MLG19PNAWW Dryer - Gas
Maytag MLG19PNDWW Stacked Laundry - Gas
Maytag MLG19PRAWW Dryer - Gas
Maytag MLG19PRAXW Dryer - Gas
Maytag MLG19PRDWW Stacked Laundry - Gas
Maytag MLG2000AWW Stacked Laundry - Gas
Maytag MLG2000AXW Stacked Laundry - Gas
Maytag MLG23MNAWW Stacked Dryer - Gas
Maytag MLG23MNFWW Stacked Dryer - Gas
International MLG23PDAGW Dryer - Gas
Maytag MLG23PDAWQ Dryer - Gas
Maytag MLG23PDAWW Dryer - Gas
Maytag MLG23PDAYQ Dryer - Gas
Maytag MLG23PDFGW Stacked Dryer - Gas
Maytag MLG23PDFWW Stacked Dryer - Gas
Maytag MLG23PDFXW Stacked Dryer - Gas
Maytag MLG23PDHGW Stacked Dryer - Electric
Maytag MLG23PDHWW Stacked Dryer - Electric
Maytag MLG23PDHXW Stacked Dryer - Electric
Maytag MLG23PRAWW Dryer - Gas
Maytag MLG23PRFWW Stacked Dryer - Gas
Maytag MLG23PRFXW Stacked Dryer - Gas
Maytag MLG31PCAWQ Dryer - Gas
Maytag MLG31PCAWS Dryer - Gas
Maytag MLG31PCAWW Dryer - Gas
Maytag MLG31PCBWQ Stacked Dryer - Gas
Maytag MLG31PCBWS Stacked Dryer - Gas
Maytag MLG31PCBWW Stacked Dryer - Gas
Maytag MLG32PDAWA Stacked Dryer - Gas
Maytag MLG32PDAWW Stacked Dryer - Gas
Maytag MLG32PDBWA Stacked Dryer - Gas
Maytag MLG32PDBWQ Stacked Dryer - Gas
Maytag MLG32PDBWS Dryer - Gas
Maytag MLG32PDBWW Stacked Dryer - Gas
Maytag MLG33PDAWS Dryer - Gas
Maytag MLG33PDAWW Dryer - Gas
Maytag MLG33PDSWS Dryer - Gas
Maytag MLG33PDSWW Dryer - Gas
Maytag MLI7000AAW Small Appliances
Maytag MLI7500AAW Small Appliances
Amana MLMTK1 Misc / Accessory
International MLR1100AJQ Range - F/s Std Gas
International MLR1100AJW Range - F/s Std Gas
International MLR1110AJQ Range - F/s Std Gas
International MLR1110AJW Range - F/s Std Gas
International MLR1415AJQ Range - F/s Std Gas
International MLR1415AJS Range - F/s Std Gas
International MLR1415AJW Range - F/s Std Gas
International MLR4410BXH Range - F/s Std Gas
International MLR4410BXL Range - F/s Std Gas
International MLR4410BXT Range - F/s Std Gas
International MLR4410CXH Range - F/s Std Gas
International MLR4410CXT Range - F/s Std Gas
International MLR4451AJQ Range - F/s Std Gas
International MLR4451AJS Range - F/s Std Gas
International MLR4451AJW Range - F/s Std Gas
International MLR5755QDQ Range - S/c F/s Gas
International MLR5755QDS Range - S/c F/s Gas
International MLR5755QDW Range - S/c F/s Gas
Frigidaire MLSE62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSE62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSE62RFW0 Frg(v2) / Laundry Center
  #2 (permalink)
Old 12-06-2012, 06:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Sounds like the problem is a bad machine (main) control board which is located in the dryer cabinet. You have nothing to loose if you order it from APP to give it a try because you can return the part if it would not fix the problem. You also may want to check all wires and connections.
- The main control board Part number: 22004325
Here are the breakdown diagrams and Parts for Maytag MLE2000AYW Washer Dryer Combo - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-06-2012, 06:43 PM
HHB HHB is offline
Junior Member
Default
Thanks for the reply Gene. Are there any known connection points on this machine that cause issues?
Also, would any of the micro or out of balance switches cause this issue? I ask because when I was troubleshooting, it actually run through one full cycle like normal, but it only happened once and I couldn't get it to do it again.
The troubleshooting flow charts were a little difficult to follow given my symptoms. I did consider getting a new machine control board, but wasn't sure if something else could be the culprit before going that route?
  #4 (permalink)
Old 12-06-2012, 06:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by HHB View Post
...Are there any known connection points on this machine that cause issues?...
...I got it to actually run through one cycle once, but couldn't get it to do it again...
I don't know any special besides those which are at the control boards, the timer and the motor.
This points to a loose connection.
__________________
  #5 (permalink)
Old 12-06-2012, 08:14 PM
HHB HHB is offline
Junior Member
Default
Thanks Gene. I removed the connectors on the machine control board before taking it out for inspection, and I removed the power connector and the JP4 connectors on the motor control board to do the test, and no luck on reassembly.
So it sounds like one of the switches couldn't cause this issue and I should focus on the connections then? I think I'll start by making sure the motor control board is getting 120 AC after the machine finishes filling, and work backwards from there if that sounds like a good plan?
  #6 (permalink)
Old 12-07-2012, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, it does. Keep us posted please.
__________________
  #7 (permalink)
Old 12-08-2012, 05:45 PM
HHB HHB is offline
Junior Member
Default
Thanks Gene. I took a look at the schematic and saw that there are 3 switches in series, the upper and lower tub displacement as well as the inertial unbalance switch. So I disconnected the lower RH connector and used an ohm meter to check the switches. All were closed. So I disconnected the lower LH connector and checked the continuity of the Door Lock Spin Enable switch and it was good when I toggled it manually. Put the connectors back together and the machine ran a complete cycle. Got 2 washes done, and on the third, it stopped again after filling and turned off. So I disconnected the lower RH connector and plugged it in again, and the machine started and finished the cycle. This happened one more time.
I just took that connector apart and squeezed the sockets in hopes of making a tighter connection with the pins in the bottom half, but when I reassembled and ran another wash, same thing happened, filled and turned off.
At that point, when I press the start button, the machine agitates once, then pauses (which I believe it's supposed to), and about a minute later it turns off completely. If I press the start button at this point, it does the same thing, agitates once... then eventually turns off. It almost sounds like for a tiny fraction of a second that it begins the second agitation, then stops. I checked the lower LH connector and 120V is present to the motor control board right up until the machine shuts off, and the 24V DC signal (BU31) is also present until it shuts off, so that's not intermittent from the machine control board.
Any suggestions at this point would be greatly welcomed! Thanks.
  #8 (permalink)
Old 12-08-2012, 09:22 PM
HHB HHB is offline
Junior Member
Default
Just did some more testing, and I think I'm getting closer to the issue. I checked the resistance of the windings in the motor, all were the same at a little over 7 ohms. So for the heck of it, I re-did the motor control board test with the external power cord, but this time with water in the drum, just to see what would happen. Motor ran at about 50 RPM for about 30 seconds then stopped. So I figured maybe the test wasn't designed to be run with a load, so I drained the water out of the drum and did the same test. Motor started spinning at 50 RPM for about 35 seconds, then stopped. So I ran the test again, this time I put the volt meter across 2 of the windings and got 120 when the motor was running, but went to 0 when the motor stopped.
I should note, when I initially plug in the external power, I hear a "click" from the relay on the motor control board and then the motor starts spinning. Even though the motor stops during the test about 30 seconds later, the relay is still engaged and doesn't click again until I unplug it. When I plug it in again immediately after it shuts off, the relay clicks again and the motor starts turning, but this time the motor only runs for a few seconds then stops, and the voltage on the meter again goes to zero. Can I infer from this that the motor control board might not be supplying constant power, or is the tach circuit somehow involved too when running this test? Is there any way to hook the motor directly to an AC source?
I should also say that it looks like the motor control board and the motor has been replaced once (a while back?) as there are wire nuts on the R, B, and Y wires to the JP4 connector (I checked the continuity of the wire nut connections, and they're fine), and both the motor control board and the motor itself look different from the illustrations in the troubleshooting manual in terms of the separate tach connector (manual has it separate, mine has it integrated). Any way to tell if this may have been replaced under warranty or when?
Sorry this is getting so long, but I'd like to get to the bottom of this and appreciate any help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag neptune washer Jmmstover@hotmail.com Washer Repair 2 06-02-2012 06:15 AM
Maytag Neptune Combo Washer/ Dryer wont spin (washer) HLSerrano Washer Repair 5 04-02-2012 01:20 PM
Maytag neptune washer sideloc50 Washer Repair 6 03-05-2012 02:38 PM
Maytag Washer Shuts off by its self bsheva Washer Repair 2 01-24-2011 06:28 PM
Maytag Neptune Gas Dryer shuts off Munister Dryer Repair 0 01-08-2011 03:37 PM
