| » Wrong water temps when washer fills |
Model Number: WTW5200VQ2 Brand: Whirlpool Age: 1 - 5 years
I already checked and the hot and cold hoses are not blocked. Water selection is listed first and actual water temp filling the washer is listed second in the following....cold-cold, cool-cool, warm-cool, hot-cool. When I shut off the cold water to the washer here is what I get....cold-no water, cool-no water, warm-hot, hot-hot. When I shut off the hot water here is what I get.....cold-cold, cool-cold, warm-cold, hot-cold. So there is hot water getting to the washer thru the hose but it just doesn't get into the washer (or only does minimally) if both the hot and cold shutoff valves are open. Any help is greatly appreciated. I want to buy a replacement part to get it working correctly again. I can supply any other information needed to help diagnose this problem. Thanks.
Ads By Google Related Models Last edited by dIYwannabe29 : 12-05-2012 at 07:51 AM. |
With your symptoms the ATC (automatic temp control) switch is the most likely suspect. Try replacing it and see if that fixes things. If you buy from this site and the ATC switch is not the problem you can return it.
__________________
| Display Modes | |
| Water temps off | Craig007 | Washer Repair | 1 | 03-28-2012 09:14 PM |
| Washer only fills with hot water, no water during rinse cycle | rcmedrec1 | Washer Repair | 1 | 08-05-2011 06:28 PM |
| Washer fills with water and that's it | marylousnews | Washer Repair | 3 | 10-12-2010 11:22 PM |
| water temps wrong | ronhinshaw | Washer Repair | 0 | 07-06-2010 08:28 AM |
| Whirlpool Washer banging when mixing water temps | lisarvot@comcast.net | Washer Repair | 1 | 04-14-2009 02:26 PM |
