Discuss
Whirlpool washer needs help
 in
Washer Repair
I posted a YouTube video of the symptoms at Whirlpool washer LSR5233AW0 leaking spinning slow - YouTube If I could
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer needs help
  #1 (permalink)
Old 12-04-2012, 05:15 PM
Junior Member
oconnbs is on a distinguished road
Question Whirlpool washer needs help
Model Number: LSR5233AW0   Brand: Whirlpool   Age: More than 10 years
I posted a YouTube video of the symptoms at Whirlpool washer LSR5233AW0 leaking spinning slow - YouTube If I could determine what needs to be done and what parts and tools I need, it will help me decide whether I should try to repair it or buy a new washer. Symptoms are:
1. Leaked water
2. Burning rubber smell
3. Clicking or clunking noise
4. Spinning very slow
5. Water did not drain
It is very hard to turn the inner tub by hand and it seems like there may be a foreign object jammed between the inner and outer tubs.
Ads By Google
Related Models
Whirlpool LSR5233AW0
Whirlpool LSR5233EQ0
Whirlpool LSR5233EQ1
Whirlpool LSR5233EQ2
Whirlpool LSR6132BN0
Whirlpool LSR6132BW0
Whirlpool LSR6132BW1
Whirlpool LSR6132DQ0
Whirlpool LSR6132DZ0
Whirlpool LSR6132EQ0
Whirlpool LSR6132EQ1
Whirlpool LSR6132EZ0
Whirlpool LSR6132EZ1
Whirlpool LSR6132HQ0
Whirlpool LSR6132HQ1
Whirlpool LSR6132HZ0
Whirlpool LSR6232JQ0
Whirlpool LSR6232JQ1
Whirlpool LSR6232JQ2 Automatic Washer
Whirlpool LSR6233BG0
Whirlpool LSR6233BN0
Whirlpool LSR6233BN1
Whirlpool LSR6233BW0
Whirlpool LSR6233BW1
Whirlpool LSR6233DN0
Whirlpool LSR6233DW0
Whirlpool LSR6244AG0
Whirlpool LSR6244AN0
Whirlpool LSR6244AW0
Whirlpool LSR6332KQ0
Whirlpool LSR6332KQ1 Automatic Washer
Whirlpool LSR6334LQ0
Whirlpool LSR6334LQ1 Automatic Washer
Whirlpool LSR6335LQ0
Whirlpool LSR7010PQ0 Automatic Washer
Whirlpool LSR7010PQ1 Automatic Washer
Whirlpool LSR7010PQ2 Automatic Washer
Whirlpool LSR7133KQ0
Whirlpool LSR7133KQ1 Automatic Washer
Whirlpool LSR7133PQ0 Automatic Washer
Whirlpool LSR7133PQ1 Automatic Washer
Whirlpool LSR7133PQ2 Automatic Washer
Whirlpool LSR7200EQ0
Whirlpool LSR7200EZ0
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0
Whirlpool LSR7233DQ1
Whirlpool LSR7233DW0
Whirlpool LSR7233DZ0
Whirlpool LSR7233DZ1
Whirlpool LSR7233EQ0
Whirlpool LSR7233EQ1
Whirlpool LSR7233EW0
Whirlpool LSR7233EZ0
Whirlpool LSR7233EZ1
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
  #2 (permalink)
Old 12-04-2012, 06:19 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Need to remove the cabinet and defeat the lid switch for testing. Check around the pump and drain hoses for leakage. Try spin mode with the pump removed to determine if obstruction in pump is the problem. If it still makes the noise and spins slowly, remove the motor and check the drive coupling. It is normal to not be able to turn the inner tub by hand as it is held in place by the brakes which are only released when the gearcase is working in spin direction. This video will show you how to get the cabinet apart and remove the pump and check the coupler.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer alexvillalobos09 Washer Repair 0 10-25-2011 01:41 PM
whirlpool washer mad12345 Washer Repair 0 01-11-2011 09:29 AM
whirlpool washer sanford-and-son Washer Repair 0 11-17-2010 03:57 PM
whirlpool washer LILBIT Washer Repair 0 10-20-2010 07:10 PM
Whirlpool stackable washer/dryer - washer advances cycles but takes a long time LynThereDoneThat Washer Repair 4 08-24-2010 07:38 PM
