| » drain problem |
Model Number: wm2277hw Brand: -other- Age: 1 - 5 years
hi trying to find help with a lg washer model wm2277hw it will not drain gives oe code checked all drains and both pumps all are good even removed the pumps cleaned and tested them on the bench both run great. re-installed ran through 1 cycle ok then again with the oe code. called repair guy he came out same thing with one exception when he tested the leads to the drain pump they are only register at 94-97volts so i checked the outlet it is fine 120v. so my question is do i replace the mother board? is it possibly sending a wrong signal to the drain pump? or would i go with replacing the the drain pump even though it ran great independently?
Hi.
Check how far is the drain hose goes inside the drain pipe. Check the impeller inside the pump. Check the voltage drop at the outlet when the washer is set to drain. Try to plug it into the different outlet. Check the plugs at the main PCB and if that's OK - replace the main PCB Part number: 6871ER1078T Remember that you can return any unused parts back to APP even if they been installed. Here are the breakdown diagrams and parts for LG WM2277HW - AppliancePartsPros.com Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| drain problem | Tom Wardynski | Dishwasher Repair | 1 | 03-08-2011 10:46 PM |
| drain problem | jx123 | Dishwasher Repair | 0 | 11-06-2010 06:57 AM |
| Drain problem | mikey18610 | Washer Repair | 1 | 10-27-2010 07:14 AM |
| Another no drain problem | bmike | Dishwasher Repair | 0 | 08-03-2010 08:02 AM |
| problem with drain pan | tyrone | Refrigerator & Freezer Repair | 0 | 08-24-2007 08:56 AM |
