| » Frigidaire won't spin out |
Model Number: GLTF2940ES3 Brand: Frigidaire Age: 5 - 10 years
My Frigidaire GLTF2940ES3 will agitate and drain, but won't spin out. I've tried the normal, heavy, and drain/spin settings. I checked all drain hoses and pump, but no blockage. I can freely spin the drum by hand, belt looks fine. I even replaced the motor speed control board 134743500 but that didn't help either. Then I read on your forum to check error codes by pressing Start and Pause buttons and got error code E47. So do you think I need a new door latch assembly? Does that make sense, it thinks the door is open during spin cycle? But I can still hear the door locking. Any other ideas? Maybe the main control board? And can you send me the Tech Sheet for my model? Thanks.
There should be tech notes inside the lower service panel.
When this happens the three candidates are the door lock assembly, the speed control board and the main control unit. Sometimes you just have to change out each one separately. Before doing anything check the wiring between the door lock assembly and the main control unit.
__________________
| Display Modes | |
| Spin cycle drains, but doesn't spin (Frigidaire Affinity) | tsteinruck | Washer Repair | 5 | 04-23-2012 02:34 PM |
| Help, No Spin Frigidaire | coxcassie | Washer Repair | 4 | 06-28-2011 06:06 PM |
| Frigidaire Gallery Series Won't Spin On Spin Cycle | mosler | Washer Repair | 1 | 11-24-2010 02:13 PM |
| Frigidaire won't spin | wtfarrer3 | Washer Repair | 4 | 02-02-2010 08:01 AM |
| Frigidaire Washer does not spin unless I help it. | frigidaire man | Washer Repair | 0 | 12-15-2008 10:13 AM |
